Results 1 to 10 of 10
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    How do you disconnect this part?
    I have an 01.5 S4 and ever time I go to work on my engine back where the maf and Y pipe are, I go to disconnect the plastic connector piece and on the bottom of that It has a small plastic pipe that connects to the brake booster (I think thats what it connects to I could have that totally wrong)
    Anyway I cant seem to get it to disconnect and I dont want to yank on it and break it. The part is in the box in the picture below
    Also I think the earlier model S4's dont have this connection on the bottom of their plastic connector piece between Y pipe and MAF I cant think of what this piece is called either. It will come to me someday.
    Jerbel, this is where you reply and give a nice detailed answer how to disconnect it and correct name of parts I am describing. You are king
    Last edited by gointoscott; 07-17-2008 at 05:35 PM. Reason: If I could ever learn to spell
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Dec 06 2007
    Calgary, AB, Canada
    Re: How do you disconnect this part?
    LOL, that's the brake booster one-way vacuum valve. It is attached to the accordion hose. I just push from inside the accordion and gently pry it out from the outside using a flathead. Maybe spray some WD40 in there to lube it up if you're having issues getting it out.
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Excellent
    Jordan you are always reliable. I did start to use a flat head screw driver and was prying away, but I know that when ever I start to use a little force something always breaks, so I decided to hold back and get some advice.
    If and when I need to disconnect the accordian hose again I will try using my thumb on inside like you said and some WD40
    Thanks again.
    Jun 14 2007
    2000 S4
    Connecticut
    hahahaha. you late model suckers. Jordan, things like this is why 2000 was a cooler year for S4's LOL
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    just pull on it until it comes off, scott.. persistance will pay off. make sure you put some spit to lube it up before shoving it back in, otherwise it can be a pain.
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Quote Originally Posted by jungb5s4 View Post
    Hey I've been working out at Snap fitness. They dont call me Arnold for nothing JK
    I'll probably snap the thing off if I just pull till it comes off.
    Jul 07 2007
    Tempe, AZ
    just pull from the base of the hose where the nipple (i guess thats what it's called) goes into the acc. hose. it'll come. don't pull from the hose itself. that'd be kind of like pulling on a power cord from the cord like you're playing tug of war. the damn hose will get f'd up if you do it wrong. but that's probably fixable with duct tape and zip ties like everything else on hte car
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    2000 PWN3!
    That is all
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Veteran Member Three Rings TRANS4M's Avatar
    02 Imola S4
    VA
    just pull on it until it comes off, persistance will pay off.
    we still talking about cars?
    Feb 19 2007
    La Crescent, MN
    Quote Originally Posted by TRANS4M View Post
    Wow, that is pretty dirty sounding... Lol that's a sig worthy quote right there!
