Results 1 to 26 of 26
    Jan 08 2007
    NEW YORK
    Copper Plugs VS Platinum or Iridium
    Which plugs work best for a chipped S4? I was told by an Audi Tuning mechanic that cheaper copper plugs will give more power, performance, and juice then the very expensive Platinum or Iridium plugs. Any suggestions or comments? What name brands and type do you use?
    Senior Member Two Rings Splinter's Avatar
    Jan 31 2008
    B.C., Canada
    Re: Copper Plugs VS Platinum or Iridium
    Copper apparently work better because they dissipate heat quicker than platinum or iridium, but they only last about 5-10k miles. So if you don't mind changing them every oil change, go with copper, otherwise platinum or iridium. I recently put in NGK BRK6E's (iridium, one step colder because i'm chipped) and they seem to be working just fine.
    Veteran Member Three Rings Grangalan's Avatar
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    It's always been a general rule of thumb that platinum plugs arent good in a FI car.
    --Black 2001.5 -S4- 10secS4 Tuned
    Oct 31 2005
    Ashburn
    i'm stll fighting boost laks but so i don't know how they perform yet, but i have DENSO Iridiums
    - Instagram: @Sinister_rs5-
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by Grangalan View Post
    I would just love to see some evidence that this is true. I've never seen any data that indicates that platinum plugs actually cause lower power output than copper.
    Apr 05 2007
    Quote Originally Posted by The_Jerbel View Post
    seriously.. if platinum isn't good for force induction then Audi must be really stupid to put in platinum plugs as OEM equipment, eh?
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Jerbel's a AZ Moderator now! I knew it was a matter of time.
    If you have been for a little while and I just noticed, my bad
    Otherwise good to see
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Dec 06 2007
    Calgary, AB, Canada
    Haha, thanks buddy. It's only been a few days, you're not missing much
    Jun 14 2007
    2000 S4
    Connecticut
    the Bosch F5DPOR Sidefires are platinum.. they were OEM on cars a long time ago (early 90's) from Audi. I started running them and my car is running much smoother so i dont know what thumb that rule comes from !
    Apr 05 2007
    yeah i've gone through the following plugs in the last month, for idle misfires, and other reasons (i.e. seafoaming so changed after, etc):
    NGK PFR6Q
    NGK BKR7E
    BOSCH F6DTC
    BOSCH F5DPOR
    The two smoothest were BKR7E and F5DPOR. Overall I like the F5DPOR best as they definitely make my idle the smoothest (albeit after changes listed below, so...can't give full credit). In defense of the F6DTC I was running it while having some timing/pingin issues on a unitronic tune i was trying, so i never gave it a full opportunity.
    After seafoaming and receiving an updated tune file, my idle misfires are very, very low now. I think I might go back to BKR7E just to see how the are after my updated changes.... but yes, the F5DPOR are very good.
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Don't mean to threadjack, but how easy is it to replace the sparkplugs?
    2015 B8 SQ5
    Click Here
    Past
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    Easy
    – Some move the pipe
    Remove engine cover. then CP's
    Remove plugs
    – Install new spark plugs.
    Tightening torque: 30 Nm (22 ft lb)
    reverse
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Feb 17 2008
    Ottawa Ont.
    Quote Originally Posted by SoEvoL View Post
    Easy
    Remove plugs
    reverse
    you cant use a torque wrench on crushgasket plugs.
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by BastardS4 View Post
    well..you *shouldn't* no.. but assuming you're using anti-sieze and have a good wrench, you should be able to without having to worry about stripping threads, since I'm sure it would be hard to identify when the washer makes contact with the head after 100K of dried up anti-sieze. Such was the case with my old Mazda and I never had issues with crush-washer spark plugs and 22ft/lb torque, nor have I had issues with my 1.8T A4. I mean, the NGK themselves lable torque specifications for gasket type plugs on the box in addition to the 1/2-2/3 turn rule.
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Where does everyone order their plugs from online?
    After Seafoaming and chipipng with GIAC, I'm looking to change plugs as well.
    Also, what is the recommended gap of the NGK BKR7E's?
    Sep 19 2008
    Toronto, Canada
    Anyone? Specifically the gap on the NGK's.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by CONTROL ONE View Post
    I'm installing a set right now. I'm gapping mine to .028
    08 S4- Stock SOLD
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    LOL you need to take that back.
    i dont know what ass you pulled that out of but its not true
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Quote Originally Posted by ThirdStrike View Post
    It's not that they're not good, it's that they get eaten up.
    I order through sparkplugs.com
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    iridiums are probably the best way to go
    try a NGK BKR8EIX
    BKR7EIX's are too hot imo
    coppers will work fine also but they wont last long. esp on a stage 3 car.
    gap should be .25 to .32
    .28 works well for my car
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by pit viper View Post
    huh?
    do you guys get your info from experience or theory?
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    huh?
    Well, in my case, experience on my SRT-4.
    Those engines tend to be spark-plug intensive.
    Sep 19 2008
    Toronto, Canada
    try a NGK BKR8EIX
    So are you saying that BKR7's are still too hot even though they are 1 step colder than stock?
    Do you mean for a Stg 3 or Stg 2?
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    rule of thumb I've always heard is 1 step colder for every 75-100 hp.
    Sep 19 2008
    Toronto, Canada
    So going by that, I should be fine with BKR7E's with a Giac-x chipped, stock exhaust S4. Done.
    Apr 13 2008
    Tennessee
    Re: platinums being "bad" in turbos cars
    so, according to the guys at Audifans, platinums in a turbo car were a bad idea due to the electrodes and insulators having problems with the pressures from the turbos, except the side fire F5DP0R worked well, probably because it was a factory plug for the 200 20v back in the day
    center electrode wearing away
    turbos extinguish sparks (probably false there, buddy)
    rebuttal of spark extinguish theory
    Tech tip from the well-known Ned Ritchie from Intended Acceleration
