Results 1 to 18 of 18
    Jul 03 2007
    Fairfield CT
    Replacing spark plugs and have a few questions???
    okay so first off is there a dyi for this procedure.
    also any little tricks.
    and i was looking and the 1st plug if standing if front of car and looking down seems to be under the intercooler piping. do i need to remove this piping in order to pull it out.???
    thank you and any comments would help i want to get his done before waterfest his weekend.
    chris
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Replacing spark plugs and have a few questions???
    It's a very easy job. You don't have to move the inlet piping. Just remove the 2 10mm bolts per coil and pull them out. You can do it in 30 minutes drinking a beer and taking your time.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by RolledMySTi View Post
    You don't have to move the inlet piping....
    Unless you have K04 inlets...
    Oct 31 2005
    Ashburn
    - Instagram: @Sinister_rs5-
    Apr 05 2007
    Quote Originally Posted by The_Jerbel View Post
    c'mon Jordan.. i thought you were Wrenchmaster2000. I have no problem getting the two front 10mm bolts on the coils w/ my inlets.
    driver side: move rubber hose along side to top of coil, squeeze in 1/4" socket 10mm.. it's a tight fit, but will work.
    pass side: use 10mm ratcheting box end (hell you can use open too) and reach in from the front of the vehicle.
    you have to play a little tetris to get the electrical connections off, and rotate the coils out...but it's pretty easy.
    Dec 06 2007
    Calgary, AB, Canada
    LOL, don't get me wrong, I've never had to remove the inlets or anything, but it's easier to get the cp's out if you just remove the 10mm bolts holding the inlets in place and move them over 1/2". I just use my cordless drill with a socket adapter and zip out the bolts that way. They take about 1/2 a second each using that method IME, it's quicker to move the inlets over half an inch and then use the drill than to screw around with positioning wrenches into small spaces to access the bolts...
    Apr 05 2007
    yeah but then you don't have the satisfaction of doing the finger-dance to not drop the coilpack bolt as you ease it out of the crevice. haha.
    Dec 06 2007
    Calgary, AB, Canada
    I'm ok with that
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    Here's another walk through that's a bit more comprehensive in that it shows some of the beginning portions of the project. Note, this is for an Allroad and A6, so the coilpacks are attached differently. The other thing I would recommend is remove the airbox entirely and without taking it apart...it will give you more space and I think makes it easier to put back in with all fasteners in place.
    http://www.audiworld.com/tech/eng82.shtml
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    one thing i do that makes it alot easier is i keep the airbox together and remove the whole thing. those back clips are a bitch lol
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    what are the best spark plugs to use? (2000 S4 6MT Stage 3) and how do you know if you need them replaced (just bought the car)
    Feb 17 2004
    Sterling, VA
    I'm running the Bosch F5DP0R plug. They are 2 heat ranges cooler than stock but, they never misfire and never foul.
    They are a side-fire plug with a very wide center electrode in comparison to plain jane Bosch Platinum plugs.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Dec 06 2007
    Calgary, AB, Canada
    IMO you can't go wrong with Bosch platins side-fires.
    Feb 17 2004
    Sterling, VA
    I've got about 10K on mine now. Still misfire free.
    Brett - Moderator
    Issue?: email me.
    May 23 2008
    Columbia, SC
    so unless my car is misfireing, I don't need to replace them? Car runs great with no CEL
    Dec 06 2007
    Calgary, AB, Canada
    Not necessarily. Sometimes fouled plugs can contribute to knock values and CF's.
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    I think its easier to leave the inlets in, driver side inlet no problem,
    Pass side though for the bottom right youll have to use a skinny wrench
    May 23 2008
    Columbia, SC
    What would "normal" Knock values and CF's be for a stage 3? And what log blocks are they? Also...is there a website that is exclusive to our cars showing vag-com "normal" values for all log blocks so I can compare?
    Also: should you replace the coil packs when doing this, if so with OEM?
