Results 1 to 6 of 6
    Veteran Member Four Rings lrg8683's Avatar
    Nov 01 2005
    S4
    VA
    question for folks with AVIC D3's
    how's your radio reception? some of the stations that should be strong kinda come in and out...
    also, have you been able to pull out the radio since installing it? if so how'd you do it? i wanted to pull it out and check the antenna connections again.. but it's in there pretty firmly.
    aside from that the thing is awesome.. sounds way better than the bose system.. and everythign works.. best part? only cost me 500 bucks.
    -Luis
    Veteran Member Three Rings saucys4's Avatar
    May 30 2007
    San Diego/SF Bay Area
    Re: question for folks with AVIC D3's
    FM has horrible signal right now. i think my antennae became disconnected. I removed it before with just a flathead screwdriver and it was fine. Awesome unit indeed.
    J Fonz Stage II+
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    hmm, wondering this as well..are you talkin about 101.1 and stuff...same issue here...well i have dead spots i guess that i never had with just the regular stereo...but i love the d3.
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Jan 10 2007
    VA
    if your reception is bad it is likely because you needed an amplified antenna adapter, which has a power wire in addition to the basic plug adapter. mine needed it, and now i get near oem radio reception, no dead spots.
    Nov 01 2005
    S4
    VA
    i thought i got an amplified antenna adapter.. i thought it came with the kit.. i connected it to the "antenna" cable on the AVIC.
    -Luis
    Veteran Member Three Rings tbone5446's Avatar
    Nov 16 2006
    b5s4, 85 4runner T3/T4 turboed
    San Diego
    crystal clear reception here, but then again it is usually in ipod mode
