What are the commas for? Did you lift off the gas pedal at 3400rpm? Why so early? A good log would be in 3rd gear from 2000rpm up to about 5000rpm and your throttle position should be at 100% (wide open). There is some helpful VAG-Com logging info here:
http://audizine.com/forum/showthread.php?t=43545
In the future: Two easy methods of posting up logs here are 1) via screen capture and post up that image, or 2) upload the csv file to google documents and share the document with the public and link it here.
Originally Posted by
FourRings80
Did a few vag-com measuring blocks today and something got my attention in my MAF logs. It seems abnormal to me that after releasing the gas the g/s could fall to 1,56 at 2920 rpm and at 5,5 g/s at 2360 rpm......could someone explain to me whats up? sign of a failing MAF?
To answer your question about why the MAF readings fall when you let off the accelerator...
You let off the gas pedal, the ECU registers this and closes the throttle plate. As a result of closing the throttle the engine is at idle (in regards to air and fuel). At idle the MAF readings are in the 2-3 g/sec range. If you were shifting gears this would happen for a split second (or how ever long it takes you to shift gears). If you were accelerating in gear but just let off the gas and let the engine decel on its own, then the logs would show this even though the rpm is up around 2900rpm and falling.
Does this make any sense? That is the easiest I can boil it down to without getting long-winded.
