Results 1 to 8 of 8
    Established Member Two Rings 0000VW's Avatar
    Jan 10 2008
    2.0SOSLOW JETTA; 03 B6 A4
    North Carolina
    collapsing of a TIP underload?
    When i boost particularly from 2nd to third everyonce in a while when i hit it i get a crack crack crack... with a powerloss untill i let off. it doesn't do it untill i boost hard. what does it sound like when you stock TIP collapses? want to know what will fix that never thought i really needed a TIP untill i went ko4 or BT i have APR stage 1+ currently
    Just keeping up with the rest of them...
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    Re: collapsing of a TIP underload?
    Quote Originally Posted by 0000VW View Post
    Not sure about the crack crack crack... that leads me to think it's not the TIP collapsing.
    Mine would lose power like you say, but the sound simply seemed muffled. IIRC.
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
    Buncha motorcycles
    Memphis, TN
    my TIP used to collapse under high boost, especially on the interstate under heavy boost... JJ TIP fixed it and saw increased power and spool
    Its up for sale BTW PM me
    APR Stage 2/AWE Intake
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Are you under stock programming or an ECU flash?
    We (ASP) saw my OEM (stock) TIP collapsing around 5000rpm under WOT with just a simple ECU flash (and stock injectors).
    Under stock programming I never had a problem.
    -Doug
    Buncha motorcycles
    Memphis, TN
    damn dougy, u are usually pretty sharp! he has APR 1+ (last line)
    i know when i pull full boost (about 23lbs) it used to surge really bad, JJ tip, it all went away
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Papachristou View Post
    Honestly, I only read the thread title and didn't read any posts. I was replying to a few tech threads at the same time. My mistake.
    -Doug
    Jan 10 2008
    North Carolina
    It sounds like a surge issue right around 20psi makes sense to me whats the condition of your TIP up for sale?
    Buncha motorcycles
    Memphis, TN
    i know doug, u dont miss much!
    the TIP is stainless steel so its perfect! two adapters are silicone
