Project: Timing belt replacement. Idea is to get it done so I can drive to Waterfest Friday.
ISSUE: I fuct up the new front crank seal I was installing. I bought the Ultimate Timing Belt Kit from ECS for the correct eng code (AEB), but it still seemed to me to be a bit too large in diameter.
I removed the old one w/ the self tapping screw and a pair of diag's/wire cutters. So there's a small hole in it no wider than the shank of a thumb tack.
I'm at work, home is 56 miles away, all highway. Is there any chance of plugging the hole on the old one to make it home? I know I can't find a front crank seal here, but I can probably find one in my hometown.
Thanks in advance.
How much oil pressure is at the front crank seal? Is it actually pressurized or is it a the type that only gets oil splashed on it?
