Results 1 to 10 of 10
Thread: Opinions please
    Senior Member Three Rings SportSter's Avatar
    Jan 28 2008
    Silverado 2500 TD 2005 Audi A4
    San Diego
    Opinions please
    Like title says, would you gamble on this?
    http://www.namotorsports.net/detail...._cd/NPTPB.019T
    2005 Audi A4 1.8t Quattro 6spd
    Stassis Suspension, H&R Sway Bars, Revo 1, Upgraded Front Brakes, s/s brake lines. More to come!
    1999 Silverado TD (597 lb TQ @ 32lb boost), Upgraded Turbo, Mechanical Waste Gate, Heath chip, front mount inter cooler, cold air snorkel, 4" straight pipe exhaust, 3.5" down pipe, upgraded injectors, pump, and lift pump, PMD Isolator, twin thermostat cooling system, 130 GPM water pump, Pillar Gauges, 3" body lift 35" tires.
    May 24 2007
    Southern California
    Re: Opinions please
    i wouldnt. i think Capt. Obvious once said it. but i live by "buy nice or buy twice"
    Kyle
    2.0L Revo GTRS Eliminator
    Registered Member One Ring 3point0's Avatar
    Jun 20 2008
    Burlington, VT
    Re: Opinions please
    Really feeling like that would get in the way of other instruments and get really annoying... it's probably set up so you have to tilt the wheel all the way down in order to make it a practical system. I wouldn't; mount it on the pillar or somewhere on your dash.
    B5 2.8LQM SOLD!
    2001.5 2.8LQM Sport, blue on gray • S-Line • 20% all-around tint • debadged • 6000k Xenons • chrome mirror and pillar covers • Kenwood 1200W amp, 2 Kenwood 12" subs • Escort 8500x50B RADAR/LIDAR detector • Kenwood in-dash navigation • 18" Avarus AV5, Toyo rubber • Eibach-lowered • Borla exhaust with 2.5" pipes • B&M SS
    Jan 28 2008
    San Diego
    Re: Opinions please
    I attempted to make a pillar monted cluster (and sell it) but was told it messed with the airbag system so I never got the balls to do it.
    Veteran Member Four Rings AudiHere04's Avatar
    Nov 21 2005
    568HP%20FWD%20A4
    East Coast
    Re: Opinions please
    buy the podi...contact winston
    Buy My Parts!
    Precision 6262 Turbo needs a core - $800
    B6 Thule Evo Roof Rack - $300
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    Re: Opinions please
    a boost gauge is a gauge, your buying quality usually like the connectors and build of gauge, accuracy and such. people seem to like winstos so go with that
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: Opinions please
    The podi has the same interference with visibility, and from what I understand, also requires the steering column to be lowered. That's enough of a turnoff for me for both units.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: Opinions please
    Quote Originally Posted by kwimberly View Post
    Just barely. You'd have to have a really weird driving position (or really short arms and really long legs) to have this interfere with your comfort.
    And personally, I like how the Podi blocks just a little bit of the gauges... now I don't have the ever increasing mileage of my car staring me in the face every time I drive it!
    -Darrick
    Veteran Member Three Rings oregonaudi's Avatar
    Oct 06 2006
    Re: Opinions please
    Oops, I was referencing the post above. Sorry Darrick.
    You don't really have to lower anything with the podi. Unless, of course, you are frequently driving under 20MPH and are dying to know exactly how fast you are going.
    Don't buy that shit. Support an AZ'er and spend 40 more bucks and get something tested and approved
    Modded 2003 1.8TQM - GONE
    NOW - 2007 Ibis S-Line Avant 6MT
    RAI KOR-GT ** S3 Injectors ** 034 TIP/Custom CAI ** Uni Tune ** APR HPFP ** Racetech FMIC ** 034 HFC W/ Labree Downpipe and Custom Exhaust ** BSH Stage 2 PCV Fix ** Southbend Stage 3 Daily ** DTM 25th S4 Front W/ DTM CF Splitter ** Painted Vorsteiner Hood ** iForged DTMs W/White Lips
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: Opinions please
    Actually we don't have the same interference at all. We block less.
    Need the steering column to be lowered? Don't know why you would need that as our pod replaces the OEM one perfectly.
    We also don't need you to drill holes to run wires, use velcro or double sided tape to fasten the pod to the OEM cover.
    But then I'm not trying to sell you as to which one is better.
    If you are looking at saving some money... check out our 'scratch& ding' sale that is going on now.
    And before you ask me how bad the scratch or ding is... you should ask the people who have bought them.
    Some are STILL looking for it.
