Results 1 to 6 of 6
    Veteran Member Four Rings the_pirate's Avatar
    Apr 08 2008
    Houston
    CODE Interpretation please....
    so my car has been running kind of funny lately. so i hooked up my scan tool and these are the codes i got:
    P1118 - HEATER CIRCUIT BANK 1 - SENSOR 2
    P1114 - 1 - SENSOR INTERNAL RESISTANCE TO LARGE
    P1297 - CONNECTION CHARGER TO THROTTLE VALVE - PRESSURE DROPPED
    P1649 - MISSING MESSAGE FROM ABS ECU
    then i scanned for codes in the ABS system:
    U48023 - INTERNAL CONTROL MODULE MEMORY: CHECKSUM ERROR
    and finally i scanned codes in the A/C system:
    00787 - FRESH SIR INTAKE TEMP SENSOR G89
    help a BROTHA OUT!
    History:
    2001 A4 1.8t manual swapped
    2007 GMC Sierra ext cab
    2002 Chevy Tahoe Z71
    Dec 05 2007
    Re: CODE Interpretation please....
    Apr 08 2008
    Houston
    you the man! thanks!
    History:
    Apr 08 2008
    Houston
    well that helped a little. the only code i couldnt find was:
    one more question, is the "throttle valve" related to the DV? i installed an FMIC a few weeks ago and ever since then the car has been running not as smooth....so i'm wondering if i am loosing boost. i checked all the couplers and pipes last weekend and everything seemed to be nice and tight.
    History:
    Registered Member Two Rings kextyn's Avatar
    Sep 15 2005
    2001 A4 1.8TQM
    Virginia Beach
    Quote Originally Posted by the_pirate View Post
    Are you still on the stock turbo and programming?
    Apr 08 2008
    Houston
    Quote Originally Posted by kextyn View Post
    yes. but i'm wondering if i through those codes when one of my FMIC hoses popped off while driving down the road. my CEL has been on for an 02 sensor so i didnt think to check it, but last night it was driving kind of sluggish so i didnt know if something else was up.
    i have the car on ramps right now i am going to make sure everything is secure under there.
    also my SAP has been coming on randomly while driving...i have only really noticed it when i first turned on the car now i hear it a lot more....bad or going bad SAP??
    History:
