Results 1 to 6 of 6
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    DIY Speaker grill replacement...
    I know this sounds real easy but it isn't... with that being said this should make it easy and save you some money in the process.
    My passenger side rear speaker cover was cracked and was bothering me every time I saw it; so I went to the dealer and bought a new one not realizing that it isn't just screwed in to the door card.. So to make a long story short, I searched inspected the inside to find that the cover is plastic welded into the door card and would take a little more time.
    So here it is:
    Tools:
    Drill
    Drill index
    Philips Screw Driver
    Butter Knife
    Stove
    painters tape
    Parts:
    New speaker grill
    Quick clips that help secure the door card
    1. Start by removing the door card. This is done by removing the belt line trim. Pull from the front of the door and it will pop away, note hooked end for reinstall.
    2. Remove three screws behind belt line trim and one screw under armrest in recessed hole. You should look like this.
    3. Gently pull door card bottom out, you'll hear snapping and may brake one of the quick clips (hence why you may want a few) This what they look like.
    Then pull the sides off and pull the card up out of the door. It is a little tricky but you'll get it. There are also two small whit quick clips on each end of the top of the door that you have to pull hard to get off.
    4. Next remove all connection to door and door car, door handle cable, speaker plug, and window regulator plug.
    The orange one and there is a clip on the back that you depress and pull down.
    5. Sweet, now you have the door card off and the work begins..
    6. I used a drill to break the plastic welds on the back of the speaker grill. I started with a small 1/8" and when used a larger 3/8" drill bit to break the remaining plastic away. Take your time so you don't break the plastic tabs on the door card.
    No screws..
    Time to drill..
    Pop out the old grill...
    Wow that thing was hammered..
    7. Now you can install the nice new grill. I used the painters tape to secure the grill in place nice and flush and then supported the back for the next step with a phone book may be thick enough if you live in a city but may need another book.
    Now you get to do the DIY plastic weld. I used a butter knife and the stove. If you don't have a gas stove this may be tough but I'm sure a soldering iron or torch could assist in this process.
    Press firmly until exposed plastic is melted flush with tab and pull away as to not get the knife stuck to the door. It should look like this when you are done.
    8. New grill is in so all that is left is to reinstall the door card in reverse. The screw on the bottom of the handle is a pain, I would recommend a magnetic screw driver and also to make not of how it goes in while the card is off.
    9. Sit back and admire a job well done and have a frosty adult beverage if your of age..
    Comments or suggestions welcome..
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    Re: DIY Speaker grill replacement...
    way to go, im glad the butterknife recomendation worked good for you.
    Jun 30 2007
    A4, S4
    Orange County, CA
    i had to replace a speaker grill a while ago that was cracked in the center, i just pulled it all off took some gorilla glue, put it on the tabs ( a generous amount) and held it for 5 minutes. looks like new. good write up for doing it correctly however.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Yeah, worked perfect thanks for the tip..
    May 25 2013
    laguna beach
    real happy to find this forum as the dealer said $350 to do the work.
    My problem is that i cannot see the photos. instead i get little squares with ? in each. can anyone help?
    thanks
    leo
    Veteran Member Four Rings jubei4769's Avatar
    Feb 09 2012
    79 VW Rabbit / 09 Triumph Daytona 675
    Kailua, HI
    Quote Originally Posted by leoramos97035 View Post
    thanks
    leo
    Do you have the door panels off already?
    instagram: @low_n_slo
    https://forums.vwvortex.com/showthre...le/page2&amp=1
    79 VW Rabbit 🐇
    13 VW Golf R 🚗
    09 Triumph Daytona 675 🏍
