Results 1 to 3 of 3
    Senior Member Three Rings jonsaudi's Avatar
    Jan 09 2008
    2003 A4 1.8T tip quattro
    California
    timing belt vs serpentine belt.
    Just curious to know the difference between TB and Serpentine belt? How can I tell which is which when I look under the hood?
    • 03 A4 B6 1.8T • Tiptronic • Brilliant Black • quattro • Sport Pkg //18" RS4 style rims //35% tint //Zimmermann x-drilled //Hawk HPS //CF wrapped trim.
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Re: timing belt vs serpentine belt.
    Timing belt drives your cam gears and crankshaft. On some cars and most older cars they used a chain, a timing chain. It moves everything together so that it maintains the "harmony" of the engine; timing. If it breaks then it throws off the timing, and on an interference engine design like ours and most cars, it throws of the rhythm or timing of the valves, for example you get a valve that is opened when it suppose to be closed, gets hit by a piston; breaking everything inside. The serpentine belt is the belt that drives the different components: alternator, AC compressor, supercharger, etc.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by jonsaudi View Post
    when you look under your hood, you see the serpentine belt, it uses the crank to drive the accessory parts of the engine (power steering, ac, alternator, etc)
    the timing belt you can see when you pop the timing cover off the front of the engine. It keeps the block and head in sync
    - Clint
