Results 1 to 7 of 7
    Junior Member Two Rings ct-esq's Avatar
    Jul 16 2008
    The Land of Steady Habits
    from time to time, headlights illuminate when switch is in OFF position
    For the repair gurus, your thoughts please:
    Intermittently, my headlights come on when the headlight switch is in the "off" position.
    I have a 03 A4 3.0 Q 6MT with bi-xenons.
    As you know, the headlight switch has 3 positions, off, parking and on. When the headlights come on when in the off position, switching to the parking position, turns the lamps off, but has the parking lights on. When you return to off, the main headlights illuminate.
    However, I can shut the car off and the lights go off and the battery does not drain.
    I cannot determine if it is related to heat, cold, wet, dry or anything like that. It seems to occur at any time.
    It seems to me that there can be two problems: (1) bad headlight switch in the interior or (2) short in the wire somewhere that causes the lights to illuminate.
    Does anyone else have any ideas before I buy a new headlight switch to test my theory?
    You should also know the left front headlamp auto-level motor occasionally does not raise the lamp. One or two restarts of the car get it to re-level - I haven't fixed this either.
    Are these two problems related?
    Thanks in advance.
    ct-esq
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    Re: from time to time, headlights illuminate when switch is in OFF position
    When I had the central locking unit go out in my car one of the symptoms was that when I would turn my car off w/ the headlights still in the on position they would remain on (instead of going to marker on only) until I would manually turn the switch to the marker or off position.
    To me it sounds like it may be something in the switch, but when I had my issues I came to realize everything electrial is pretty much tied together somehow. Other issues I had when my CLU went were intermittent interior lighting or it would be dim for a short period then bright as normal (this is how it started for me...then lead to the other issues); random window issues (not working or rolling down at will); alarm going off (even when driving) and the headlight thing. All the issues I had would randomly happen..sometimes fine then would have a combination of them which progressevly got to be more often then not.
    Jul 16 2008
    thanks - makes sense, i have some info that it could be the cecm, central electronic control module.
    hopefully, when i'm done, the electric gremlins will be gone!
    ct-esq
    in the garage:
    past: 03 A4 3.0 6MT Q - 168k mi + / 03 B M W 330xi 6MT - 208k mi at the end - 1998 VW Golf - from 0 to 194k at the end, 1988 VW Golf - from 88k to 192k at the end, 1980 Audi 5000 - odo stopped at 32k, 10 years before my purchase, mileage? anyone's guess (the sunroof had a crank!), 1971 Plymouth Valiant - inline slant 6, about 15 moving parts and plenty of room to work, 1985 Ford Escort (lasted 1 yr before being totaled)
    Dec 06 2007
    had the same problem changed the switch and everything has been fine so far!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    sounds like a switch...they can be had on the bay pretty cheap too. gl
    Jul 16 2008
    seems like a consensus is building . . .just need to figure out the part number for the switch - www.audipartsdepot.com lists two switches, one "w/info" and one "w/o info"
    any ideas on the p/n?
    ct-esq
    in the garage:
    Dec 06 2007
    ^^ebay FTW! there was one with Auto and one without!
    -Kirk
