Results 1 to 2 of 2
    Established Member Two Rings mattdogg02's Avatar
    Nov 12 2007
    Lucas, TX
    Problem - Air cuts off, then comes back on
    Ok, twice I'm been in my car where the air has completely cut off (its on, but the blower cuts off, the bars go to zero), then it comes back on by itself. Any ideas if something is up?
    On a side note, i've noticed with the increase in heat, when idling, my dash temp gauge (the external temp, not engine temp) is going up by sometimes +5 degrees from the actual temp. I'm assuming this is because of engine heat affecting it, but wanted assurance.
    TIA
    Established Member Two Rings SOASOAS's Avatar
    May 31 2004
    Phoenix AZ
    Re: Problem - Air cuts off, then comes back on
    My AC does the same thing every couple of weeks in the summer (this is the 5th summer for me)... haven't seen the ext temp thing though
