Results 1 to 10 of 10
    Active Member Two Rings dhmaniac13's Avatar
    Jun 30 2008
    2000 s4
    APR chip....now surging/hesitating
    Hey guys, I just got an APR chip for my 2000 A6 2.7t 6 speed with the 93 and 100 octane tunes and I now have a nasty surge/hesitation/boost leak. I can clearly hear the turbos blowing off boost at like 3k and then power stops. It runs idles perfect and revs fine in neutral and 1st but after that it cuts out. I am thinking boost leak but what do you guys think?
    Sep 20 2006
    Burnaby, BC, Canada
    Re: APR chip....now surging/hesitating
    did it start doing that right away, or some time after you got the chip done... if it was sometime after, then i really sounds like a boost leak... extra boost created by the chip blew a hose or something
    Jun 30 2008
    2000 s4
    Yah, It was perfect when I garaged it and today I chipped it and immediately it began surging. I just made an appointment for it at the Audi dealer to have the boost system leak tested. Any other insight? Thanks!
    Apr 18 2007
    ny
    Sounds like the DV's
    Veteran Member Three Rings Auburnsky1287's Avatar
    Jan 06 2008
    Orlando
    http://www.audizine.com/forum/showthread.php?t=224306
    Throttle body boot is prone to failure on the 2.7T motor. The increase in pressure is typically too much that part (and it always fails in the same spot). Samco makes a silicone replacement part and APR makes a bipipe that replaces the top clip of pipes with a single aluminum pipe. (I got the bipipe)
    Also your diverter valves will probably go bad soon if they are stock.
    You really should consult the B5 S4 forums for anything regarding the 2.7 Motor
    2001 Audi S4
    Vast Tuned Stage 3
    Senior Member Two Rings East2.7Six's Avatar
    Apr 18 2008
    Audi A6 2.7T
    New Jersey Shore/Philadelphia
    BI-pipe & new diverter valves with a K&N and your car will feel like i best from what i hear
    but thats usually the main problem if you chip your car with out getting a bi-pipe & diverter valves
    "Sometimes you gotta roll a hard six."
    Veteran Member Three Rings RAUDIS6's Avatar
    Oct 09 2006
    Stage 3 B5 S4, LS460, Mini S Countryman
    DV's X2
    Senior Member Two Rings African2.7T's Avatar
    Dec 18 2007
    B5 S4 Laser RED
    PA
    sounds like dv's. before i got my chip on my car i changed the Throttle body boot and also swapped out he stock dv's for forge
    MK4 GLI Blue lagoon
    B5 S4 Laser RED
    Past Rides
    C5 A6 2.7T
    B5 S4 Santorin Blue
    MK4 JTI VR6 Money Green..lol
    Nov 19 2005
    Pair of (. )( .)
    boost leak for sure....tbb, dv, piping, etc.
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Jun 30 2008
    2000 s4
    It turned out to be a ripped throttle body boot. A new one will be here tomorrow and I am in the process of buying new dv's. Thanks everyone!
