Results 1 to 4 of 4
Thread: Offset Help ?
    Established Member Two Rings lowsinthe20s's Avatar
    Feb 27 2007
    02 Audi A4,07 Q7 4.2 Sline
    Groveland, Florida
    Offset Help ?
    Will a 19x8 wheel with a ET of 30 fit on an 02 B6 with out sticking past the fenders?
    I tried one of the wheel offset calculators, but it's not really making since. I need pictures.
    Deactivated Three Rings
    Apr 11 2008
    Re: Offset Help ?
    19's with a 30 offset? baaallerr
    lol. according to this site, you should be cool with a 235/30 tire (but I would double-check): http://www.wheelsmaster.com/rt_specs.jsp
    Suspension: 100% clear (leaves even more room than OEM)
    Fenders: Package will stick out 15 mm (0.6'') farther. Acceptable for most cars.
    Wheelwells: Will fill out the wheelwell by extra 2 mm. Almost no difference
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Offset Help ?
    It may be really close to sticking out, as we normally do ET32 to ET35.
    Feb 27 2007
    Groveland, Florida
    Re: Offset Help ?
    Thanks for the Help guys. I like that Calculator. I'll be saving that one.
    I current have a set of RS4 reps 19.8.5 with a +38 offset running 235/35 and there kinda flush with the fenders. I also have any extra set of the same wheels and I was looking at trading for a set of Axis Wheels that are the 19x8 with ET30.
    The Axis wheels are currently on a 08 B7. I'm just not sure if there is a difference in the fender wells and suspension between that and an 02 B6.
    Thanks Again
