    Senior Member Two Rings KryptoniK01's Avatar
    Nov 27 2006
    B5 S4
    Vancouver BC
    Is it normal for the tire to run this close to the rear wheel bearing housing?
    There is only like 2mm of clearance between the arm and the tire... if I fold a piece of paper over a few times it gets friction on both sides. Is this normal?
    This is on stock 17" avus wheels with fairly new 225/45/17 Goodyear Eagle F1 A/S's
    TIA
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: Is it normal for the tire to run this close to the rear wheel bearing housing?
    yes.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Thats the way it was on my A4 when I put some 18" wheels on. However they would rub and eventually ate through the tire to the wires. Keep a close eye on it for any signs of rubbing, if you do, put some spacers on!
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Nov 27 2006
    B5 S4
    Vancouver BC
    cool, thanks.
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    Mines like that with 245s.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
