Originally Posted by
Condo
What would be needed to get a B5 S4 6speed into a B6 5spd?
I 'heard' (and, again, maybe I'm wrong here) that the B5 S4 trans is a different length, thereby requiring a different rear driveshaft. I recall reading in the B5 A4 forum about someone wanting to put a B5 S4 trans in his A4 and needing to use the driveshaft and rear end or some other schit like that.
The linkage... You'll want the linkage all the way to the shifter and probably the shifter itself (if you're coming from a 1.8 5spd) since you need the push down reverse capability.
EDIT: Read this thread:
http://audizine.com/forum/showthread...ighlight=trans to confirm or deny what I just wrote....
