Results 1 to 18 of 18
    Mar 16 2008
    Central
    What's the going rate for a full alignment?
    I was quoted bout $300 bucks for a "full body" alignment... That sounds outrageous... I've heard of the S4 getting a subframe alignment along with a 4wheel alignment but $300 bucks!!! I have gotten a quote from the dealer yet but wanted to get an average rate for aligning a 01 S4.. Oh, residing in the Kansas City metro area also.
    Thanks.
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: What's the going rate for a full alignment?
    $100 for a 4 wheel alignment
    Feb 12 2008
    01' S4/ 98' Boxster
    Lake Oswego/Corvallis
    Yeah $100-$150 at most for an alignment is what you could expect
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    go to firestone and get the lifetime 4-wheel alignment for $150 (or something like that)... you can go in there 5 days a week and it won't cost you another penny.
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Quote Originally Posted by RedRocketS4 View Post
    Really? So a one time payment of $150 gets you unlimited alignments? That rocks if it works!
    Otherwise there is a place around here that does 4 wheel alignments for $75 and they are a very reputable shop here.
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Jul 25 2007
    '01 S4 (track built w/ rs6 turbo's) , '01 TT stgII, '04 A6 stgIII (with rs6 turbo's)
    St. Louis
    I had the firestone alignment. It was ok for a while, but they ended up damaging the car, were very unreliable, and would say they aligned it but refuse to give me a spec sheet, I took it to another shop, and they didn't change a thing. I have the lifetime alignment, but I will never go back. Note that I am in St. Louis and went to several different firestones. Plus, once I got my adjustable upper control arms, they won't touch camber. I ended up asking the local SCCA guys and found someone who works at a local Sears that will do align to your specs while you watch for $60.
    IMHO, ask the local SCCA for a specific person. f*** firestone...
    May 18 2007
    Baytown, TX
    sorry you had that experience. I know most of the guys at the firestone i go to, so i know exactly whats getting done.
    Veteran Member Three Rings dgrs4sd's Avatar
    May 25 2008
    So Cal
    I have had a "lifetime alignment" on every car I buy because I always end up doing suspension, adjusting coilovers, etc.
    it is a always a good idea although make sure the place you are buying it from uses high end equipment for custom wheels and uses laser at minimum...
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    $79 at les schwab 4 wheel.
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Les scwab here in Elk Grove refused to even touch my car. Something about having to remove the steering wheel and "special tools required." I cut my losses and went to the dealership. $149.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by 2ndEngineS4 View Post
    wow im suprised, they did mine no problem in Galt They had a fun time adjusting my camber kit, took them 1.5 hours didnt charge extra.
    Registered Member Two Rings hosmer79's Avatar
    Jul 16 2008
    2001.5 Audi S4
    W.S., MA
    I recently had my TC replaced by an Audi mechanic on the side and he did my alignment after hours for $100. He said that the proper method of alignment involves loosening the sub frame to correctly adjust and he said most mechanics even at the dealership won't bother doing this. He said generally the alignment would cost $150-$200 most likely.
    Two is greater than one!
    2001.5 S4 Santorin Blue 124K
    GIAC - Darintake - Drop in K&N - 710n's
    http://i94.photobucket.com/albums/l9...orums/Sig2.jpg
    Senior Member Three Rings Muck_and_Grind's Avatar
    Jun 09 2008
    2001.5 Audi S4 (on stands), 1989 Grand Wagoneer, 2007 B9 Tribeca
    Lodi
    modesto area? free with a tire sponcer
    Mar 21 2005
    2019 RS5 SB / 2025 SQ7
    RI
    $109 from the Audi dealers around here. That's for a 4 wheel alignment and a subframe alignment, if it needs it.
    I did not know firestone had a lifetime alignment offer. That would have saved me a TON of money. I've had like 4 alignments this past year :-/
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    I am actually getting mine done today. It was $109.
    --Adam
    Have questions? E-mail me.
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    damn i love working at car-quest i get great deals everywhere including mavis tire :)
    $50 for alignment cash
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    NTB and all the other places do the unlimited alignments too. Check who does the best work in town and ask them about it. I got quoted 1 year unlimited -$100, 3 year unlimited $140, and 5 year unlimited - $180
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Mar 16 2008
    Central
    Thanks for all the reply folks... Have any of you gotten any problems with having coilovers when getting an alignment from the dealer? The shop I got quoted $300 buck was supposedly from a reputable porche/audi shop too but $300 bucks is just too expensive.
