I'm selling my car because we're getting ready to move out of the states, but the car is just so flippin sweet I'm having a hard time selling it, I may just pay for the shipment myself if it doesn't sell. She still drives, and looks like a million bucks. Nothing wrong with it mechanically and I've personally kept up with all maintenance in it since I bought it. Anyway, let me know what I should get for this flawless car, I was thinking somewhere around 9k for everything, or maybe I'll keep the rims since I'd plan on getting another Audi if I sold her. [cheers]
Located in Surprise, AZ 85374
Please email, no IM: [email protected]
1999.5 Audi A4 1.8 Turbo Quattro 5-speed Manual
You are looking at a clean Vehicle, 82,xxx miles on the odometer, Arizona Car, No Rust, and you are buying it from the second owner.
Inside, outside and under the hood, this is a clean car!
Factory Car Highlights
• Bought from Audi Dealership, Certified Pre-Owned
• Audi Dealer Serviced through 2006, Well Maintained
• Original Wheels w/All weather tires installed INCLUDED IN THE SALE!!
• Powerful 1.8L 20 Valve Turbo Motor, Always ran with 0-W40 Synthetic Oil
• Manual 5-speed Transmission, Always ran with 80-W90 Sythetic Oil
• Quattro All-Wheel-Drive Equipped
• Laser Red Exterior Paint
• Anti-lock brake system
• Seating for 5
• Dual Front and Side Airbags
• Black interior with dual front bucket seats
• Tilt Steering Wheel and Power Steering
• 27 Miles per gallon gas mileage
• Power windows with: "one touch down" for ALL four windows; "pinch protection" (auto open child safety) for ALL four windows; "one touch up" for front windows; driver controlled lock out switch for rear power windows
• Keyless entry, remote can also roll all four windows up or down from outside the car.
• Factory Alarm with Interior Motion Sensors and Panic Mode
• Driver information display (Trip computer)
• One Piece Headlights
• Headlight Washer Sprayers
• Factory Fog Lights
• Cold Weather Package: Heated front seats, Heated Mirrors, heated windshield washer nozzles, heated driver door lock, heated trunk lock, expandable trunk ski/storage sack
• Audio Package: BOSE 150w Premium 8 Speaker Sound System, 6-disc CD changer, AM/FM Radio, Cassette Player.
MAINTENANCE
• Engine Oil Changed every 5000 miles, always with Mobil1 Synthetic 0-W40
• Replaced all 4 CV axle boots
• Replace engine coolant sensor
• Brake fluid flush
• Replaced Engine Oil Cooler
• Timing Belt, Timing Belt Tentioner, Accessory Pulleys, Engine Water Pump, and Accessory Drive Belts replaced at 65,xxx miles
• Coolant system flushed during water pump change at 65,xxx miles, and serviced with 50/50 mix of VW/Audi Anitgel Antifreeze Coolant and Distilled Water.
• Instrament gauge cluster replaced Due to Faulty readings
MODIFICATIONS
• ATE Slotted Front Rotors, ATE Standard Rear Rotors
• Mintex Brake Pads on all 4 wheels
• Audi All Weather Rubber Floor Mats
• Evolution Motorsports Cold Air Intake with K&N reusable Cone Air Filter
• APR Tuned ECU Chip Installed
• Audi TT 225 Diverter Valve Installed to Accomidate Higher Boost from ECU Chip
• N75J Wastegate Controller Installed to Accomidate Higher Boost from ECU Chip
• VDO Boost Gauge Installed in Center Dash
• H&R Sport Springs with Bilstein Struts/Shocks Installed
• S4 Front and Rear Sway Bars
• Southbend Stage 2 Sports Clutch Installed at 58K miles
• 18" Oettinger RE Wheels w/ Dunlop Directional Tires
PARTS INCLUDED WITH THE SALE
• Stock OEM ECU
• Factory Carpet Floor Mats
• Extra Trunk Cargo Net
• Center Vent where Boost Gauge is
• Stock OEM N75 Valve
• Stock OEM Diverter Valve
• Stock OEM Air Box and hardware
• Stock OEM Suspension (Struts, Springs and hardware)
• Stock OEM Audi 15” 7-spoke wheels with All-Season Tires
