Results 1 to 16 of 16
    Established Member Two Rings Bfiver's Avatar
    Apr 29 2008
    2001 audi a4 1.8t
    CENTRAL~NY
    boost skippage??
    i have a b5 1.8t tip i recently did the diode mod and added a MBC.... after the mod i was boostin all over. about a week after when i run through the gears its almost as though when the boost starts to peak it feels like it starts to skip. . . a few times my engine light has flashed a bunch of times while the skipping was happening then shuts off... im sort of a newbie at all this so sorry if its not explained well.... any idea???
    C-Lo
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Re: boost skippage??
    Quote Originally Posted by Bfiver View Post
    Misfire possibly? I would start with the cheapest fix first- maybe you just need new spark plugs..
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Apr 29 2008
    2001 audi a4 1.8t
    CENTRAL~NY
    thats what i thought maybe I blew a coil pack i havnt checked yet. . . but i also turned down the boost and went WOT and i had no skipping with the boost turned down
    C-Lo
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    new plugs, gap em to .028, keep the boost at/under 15 psi on a stock chip ;)
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Apr 22 2007
    Riverbank, Ca
    Simple fix is buy the proper chip... then you have no worries..
    Apr 29 2008
    2001 audi a4 1.8t
    CENTRAL~NY
    ya i know that but.. . . not everyone has 500 bucks to spend for pleasure i wish though
    C-Lo
    Apr 29 2008
    2001 audi a4 1.8t
    CENTRAL~NY
    im pretty sure my car has coilpacks and not spark plugs
    C-Lo
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    Step
    Away
    From
    The
    Audi
    Seriously though - your car has BOTH coilpacks AND Spark Plugs.
    The coilpacks sit atop the spark plugs.
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Then maybe you should wait until you do have $500 or you might end up spending $5000 on a new motor...
    ΜΟΛΩΝ ΛΑΒΕ
    Sep 11 2007
    Dirty Jersey
    Quote Originally Posted by erikas3 View Post
    I had the same issue early this week, and a new set of nGK plugs fixed it right up
    Nine [O_O] Eight Tuning
    custom work, fabrication, bumper shaving, fender rolling, plastic & fiberglass fabrication and repair
    Turbo charged and lowered for better grocery getting :screwy:
    Apr 29 2008
    2001 audi a4 1.8t
    CENTRAL~NY
    thanks Vreihenmotor6 ...... you know not everyone in this world that owns an audi knows everything about them.... ct1.8t4me... it would be nice to be able to come on here and ask question that i dont know and get help with it rather than some dick that thinks they know it all tell me to " STEP AWAY FROM THE AUDI" try being considerate next time bud...... no need to be rude your not proving ne thing
    C-Lo
    Dec 08 2006
    Cincinnati
    Quote Originally Posted by ct1.8t4me View Post
    Step
    Away
    From
    The
    Audi
    Haha, simply amazing.
    Dec 08 2006
    Cincinnati
    Oh come on, you did in fact say your car did not have spark plugs, only coilpacks. You shouldn't get bent out of shape when someone makes a crack at ya over a funny claim/comment. You have to agree that most people who do not think their car has spark plugs should probably leave it to a shop. Just saying... No big deal though, a thick skin suits one well around here.
    Apr 22 2007
    Riverbank, Ca
    You dont have to buy a new chip... A used one would work just as well... 300 or so..
    That or turn your boost back to stock...
    GL,
    Do the right thing...
    Oct 25 2006
    Oxford, CT
    Chill out man. Honestly, my intent was comedy, not dickishness (ha!). AND I gave you the answer - or rather made a correction to your statement about not having spark plugs.
    I am not trying to prove anything on here or anywhere else on the internet.
    As an aside, and not to be a dick, but can you point me in the direction of a gasoline-powered car that does not have spark plugs? Cuz I can't think of one.
    OK - maybe that was dickish...
    Oct 25 2006
    Oxford, CT
    Now as a serious response:
    Trying to cheat and get a manual boost controller + Diode CAN work, but can also bring about very unreliable and inconsistent results. It's next to impossible to troubleshoot an issue like that without being in the car because MBC's are so finicky. Believe me - I TRIED to run an MBC with no ECU upgrade on my car, and I have an AEB - no Diode mod is going to help me. The best I could do was get 10-11 PSI out of it, but God forbid the temperature changed or the air became more or less dense and I would hit the hard fuel cut. It was just not enjoyable. You never knew how the car was going to react when you got on the gas.
    The bottom line here is that if you are going to try and save a buck (or 3-500), and use the MBC+Diode mod you are going to have to fiddle with it to get it anywhere close to "consistent". Also - what kind of MBC are you using? Are you using a bleed type or a Ball & Spring? This may also affect your results.
    After messing around with it forever and trying all sorts of low buck solutions like getting a 5-Bar FPR in conjunction with the MBC - I finally just ended up buying a used APR 91 Chip from someone on here or Passat World I can't remember. I still use the MBC to squeeze out a little more boost and to change the boost curve a bit, but the car is much more predictable with the chip - and now I'm boosting 18-20PSI without problem.
