Thread: bad EGT's?
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    bad EGT's?
    so is it possible for these to start going bad an not throw any codes (or show up in VAG)? does someone have before & after experience (replacement) that can describe symptoms...
    thanks!
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: bad EGT's?
    Quote Originally Posted by BITRBO View Post
    thanks!
    Bad gas mileage, misfires, I've never seen it not show up through a VAG scan. You can log on/off temps. Can't rember which block(s) off the top of my head. 112? It should only show one spec temp for each(on&off).
    Mar 22 2005
    2019 RS5 SB / 2017 Jeep SRT
    FL
    Re: bad EGT's?
    Yes it's block 112
    It should read 1035 with the car off and 945 with the car on. If they are bad, either they wont be reading or they will be reading something different.
    Dec 06 2007
    Calgary, AB, Canada
    Re: bad EGT's?
    You'll also potentially run rich and get a lot of hesitation and bucking.
    Mar 08 2007
    Mr. Worl-Wye
    Re: bad EGT's?
    Quote Originally Posted by The_Jerbel View Post
    Got it. I'm getting some of this already, so I was just curious. I randomly ran block 112 the other day and remember seeing 945, so these might be alright then. I double check one of these days...
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
