Results 1 to 22 of 22
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    New intake w/ heat shield ( w/ pics)
    I decided to make a heat shield this past weekend and install the new filter I bought. It was alot easier than I expected. Temps seem much cooler on the intake side as expected, and I can actually hear the bpv now
    Established Member Two Rings tre's Avatar
    Jul 07 2008
    B8 S4, B8 2.0 prestige, modded B7
    Chicago
    Re: New intake w/ heat shield ( w/ pics)
    Did you VAG the before and after intake temps?
    08' B7 A4 2.0T 6 speed quattro
    - Stasis reflash, Ohlins SL suspension, Stasis exhaust, Stoptech 355 BBK, RS4 rear sway, light OZ wheels
    2011 B8 2.0T Stock
    2011 B8 S4 Stock
    Feb 12 2004
    PA-NJ
    NO b/c I need a new VAG. I might consider doing a test like that after I get a new CAN version. I really just wanted to make my own, just to do it. The stock box is very easy to reinstall if I want to. I do like hearing the bpv again though.
    Senior Member Two Rings Grk_A4's Avatar
    Sep 18 2007
    Philadelphia
    I wanted to attempt fabricating a heat shield this past weekend but I was unsure what material to use. If you don't mind me asking, What material did you use? Where did you get it? Thanks in advance. By the way it looks great.
    Veteran Member Four Rings A4_cabrio's Avatar
    Aug 09 2004
    2005.5 A4 2.0T
    Austin, TX
    How is the "sucking of air sound" of the intake ? Is it obvious from the inside of the car?
    When I had the Carbonio intake I hated the sucking noise. I ended up removing it b/c it was too loud for me.
    2005.5 2.0T Tip Dolphin Grey / Black Interior
    Factory options: all except for Bose sound
    Added: 35% Tint, OEM Bluetooth, MFSW with paddle shifters, RS4 pedals, Brushed Aluminium mirror caps, S-line bumper, RS4 grille, Euro plate filler, 19" RS4 reps (Velocity), S4 valence, Satellite receiver, Quad tips, VMR boost gauge, AUX port
    Next mods: honeycomb fog grilles, LED DRL, Dension
    Mar 02 2007
    Brisbane, Australia
    Is that a K&N filter ? If so, what model is it ?
    Looks like it has a moulded boot that just slips over the OEM AFM housing ??
    Neat and easy solution !
    Veteran Member Four Rings agkellyboy's Avatar
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    Thanks EuroA4, you convinced me to try mine again. My setup looks exactly like yours. I used plain old aluminum covered in heapings of heat reflective adhesive material.
    Sucking sound is monstrous. You do hear the bpv as well. I love it all though!
    FS - Dolphin B7 A4 Ti 2.0T MT6 Quattro Project 400R
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    looks good. what kind of tape did you use for heat reflection/ resistance?
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Very nice Job...At last someone who took the filter box of...
    A4 B7 1.8T 20vt Quattro powered by Etuners
    Rear Valence+Trunk Air Lip+Mirror Housings+WindowTrim CF'ed, Debadged Trunk, Front+Rear Red Tie Hooks, Engine Cover Removed, Painted WasherFluid+Coolant caps, Toyo Proxes Racing Semislick R888 225.40 (for now), OZ Ultraleggera 8x18 ET45 Black, 76mm Custom Cat-Back Exhaust, OEM BlackMask w/ black Audi Badge, Sparco Suede Helmet Case, Sparco 33mm Racing SteeringWheel, RUF Snap-off WheelHub, CF ShiftKnob, ColourMatched BrakeCalipers,
    APex-I TurboTimer black, Custom BilsteinPSS Coils by Kirlagkitsis Greece, Tinted Tailights,
    GReddy Electronic Φ=60 Warning A/F, WaterTemp, OilPress, FuelPress
    Defi BFSeries (w/ link) Φ=60, Boost, EGT, OilTemp, + 1, 3x Custom GaugePods by XM Designs Greece, PIAA CityLights Super White and White, Sparco CF Pedals, Simoni Racing SteeringWheel CronoMeter, Sachs Organic Racing Clutch Kit, Custom Decals, Alcantara Shift Boot, CAI, Forge 007 DV, Black HeadLights w/ Clear Corner Mod, Removed ArmRest
    Check it here
    Soon to Come: ....HKS Power Flow Reloaded, NeuSpeed ShortShift, 830cc Injectors, Defi EGT #2, BT....
    Feb 12 2004
    PA-NJ
    The sheet metal is .22 gauge aluminum (Lowes) and I had a piece of window molding around that I used for the top seal. The material used for the heat barrier is a peel n' stick aluminized heat barrier for racing applications (Pegasus Racing). And the K&N filter is #RU-3580 which fits directly onto the MAF housing with the included hose clamp.
    The sucking of the intake can definately be heard, and does sound good IMO. This is how a turbo car should sound! I think adding a Forge bpv may be in my future!
    I have not felt any noticable gains (or loss) from this in terms of power, but I do feel a tiny bit more responsiveness from throttle application.
    Veteran Member Three Rings jahciple's Avatar
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    did you just buy that intake and slap it on the existing tube or is it a kit that you made? please explain, thanks.
    Driver: Dustin
    Projekt: Audisciple
    Gamertag: JAHciple
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    great job!! wait until the weather starts getting colder. that thing will be a beast with the cold air during the fall/winter/spring.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Established Member Two Rings GEkido's Avatar
    Apr 25 2008
    Miami, FL
    It was so nice, I went ahead and ordered the filter and also the heat barrier from Pegasus. As soon as it comes in i'm slapping that bad boy on! Thanks for the inspiration, it sure beats paying for a Carbonio or even the Evo Intake. I'll see if I make a little DIY while i'm at it.
    2021 S5 Sportback | Glacier White | Sport Package | Black Optic | APR 93 Tune | APR FMIC | AWE CF Intake | 034 F.S.B. | 10/12.5mm Spacers
    Senior Member Three Rings B7 Projectile's Avatar
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    Great minds think alike! I did the same setup, I felt a little more umph in the higher RPM's and the turbo finally is heard. I have been planning on replacing the OEM rubber intake tube with a custom steel made one (heat wrapped of course) with the help of a local exhaust fabricator in hopes that it would reduce the resistance caused by the OEM piece. In addition I wanted to take one of those brake duct tubes, or fabricate some type of redirecting shield that would shoot the air straight up from the side duct to the cone filter to give her a little more fresh air.. I plan on doing this tomorrow after installing my FMIC in the morning. Will post some pics once this is done... Just trying to throw on the mods before WF..
    2007 Ibis Audi A4 2.0TFSI Ti Package
    Vorsteiner CF Hood.APR K04.APR HPFP.AWE Exhaust.AWE FMIC.034 HFC.KW-V2 CO's.Forge DV.3000k HID Fogs.Smoked Tails.Custom Intake.Heatshield.CC Mod.35%Tint.Blacked Rings.RS4 Rear Sway Bar.Podi boost gauge.
    Ah...so many pedestrians, so little time...
    Feb 12 2004
    PA-NJ
    Quote Originally Posted by B7 Projectile View Post
    I was actually hoping Samco would have a silicone turbo inlet pipe for our cars by now! And I also had the idea for some kind of real cold air pathway from the lower bumper grills using race brake ducting or possibly a custom fender vent like the old MB Sprinter vent or Eurovan vent.
    Sep 18 2007
    Philadelphia
    thanks for the info will be fabricating a heat shield this weekend!
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    pics dont work. i wanna see
    Feb 12 2004
    PA-NJ
    Quote Originally Posted by supamannn99 View Post
    re-linked photos!
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Damn, everyone is getting on that custom heat shield thing recently. Nice job
    Ignorance is bliss.
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Quote Originally Posted by agkellyboy View Post
    X2
    Easy setup. All you need is a k&n filter, aluminum sheet and some heat reflective adhesive. The heat shield is a must, otherwise you will warp your filter! (Speaking from experience).
    Installing the K&N resulted in a noticeable throttle response, deeper exhaust note and best of all I can now hear my DV re-circulate the boost from the turbo, no BOV required. The mod cost me: $60-filter, $20-Aluminum sheet and $8-heat reflecting adhesive. EuroA4, Thank you for enlightening me!
    Established Member Two Rings themig90's Avatar
    Feb 12 2008
    2006 A4 2007 A8
    West Palm Beach, Fl
    If you guys do not want to make it this guy sells em for 80$ shipped, give him my name, Miguel. His website is http://www.blinktekdesign.com/ check it out. Ive had mine for about 6 months with the K&N cone filter and absolutly love it both the sound and performance which i do notice.
    Jan 01 2008
    Long Island NY
    nice heatshield.
