Results 1 to 6 of 6
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Rial Nogaro will they clear the damn brakes even with spacers?
    Sorry for another wheel thread, I am just in an emergency situation.....
    Will 19" Rial Nogaros clear the front brakes (B5S4)? If they cant what size spacer is needed?
    TIA
    -Sami-
    Feb 19 2007
    Charleston, SC
    Re: Rial Nogaro will they clear the damn brakes even with spacers?
    Will these stats help any?
    Stats on the Rial Nogaro
    Offset: 35mm
    Backspacing: 5.86"
    Bolt Pattern: 5-112
    Rec. Tire Size:235/35-19
    Weight: 25.4lbs.
    -Sami-
    Veteran Member Four Rings 02SILVANT's Avatar
    Aug 24 2007
    2005 Audi S4 Avant 6MT
    Vancouver, WA
    I have the same wheels and when i was purchasing them i had the same question as you if they would clear B5 S4 brakes and unfortunately they wont and i have no clue what spacer you need. i ended up buying the wheels and stayed with the stock B6 brakes.
    here is a few pics of how they look on my car:
    2002 Silver A4 Avant Auto - SOLD
    2005 Black S4 Avant 6MT - SOLD
    2005 Mercedes E500 Sport - SOLD
    2005 BMW 330ci ZHP Convert imola red with hard top - SOLD
    Currently 2015 Audi Q7 3.0T S-Line V12 TDI Body Kit
    SPARK, Mental Focused Energy Drink:https://www.advocare.com/08082595/St...lavor=L&size=P
    Feb 19 2007
    Charleston, SC
    Thanks for the pics....sending you a PM
    Is it just the backspacing that determines if the spokes will clear? My current 18" wheels with a 35mm offset (same as the Rial's) will clear the brakes just fine...so if I find out its backspacing and it is the close to the backspacing of the Rial's, would it fit?
    -Sami-
    Dec 03 2005
    2 pedals 1FG
    connecticut
    It depends on the spoke design. Backspacing does play a role but if the spokes are fairly aggressive beyond the hub flange then they may not clear the brake calipers.
    Did you figure this out? I am so torn as to do I sell my B7 RS4 reps and get something different or just continue to rock the B7 RS4 reps. Those 19" Rials in the classifieds are nice.
    -Doug
    Feb 19 2007
    Charleston, SC
    They fit with a 8mm spacer up front. Bringing the total offset to +27mm in the front. It lines up PERFECTLY with the front fenders....looks sick.
    -Sami-
