Results 1 to 37 of 37
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    hi-flow cat vs testpipe...
    In a performance optic, which is the best? Does the turbo need a back pressure? I heard different opinion about that...
    May 01 2008
    Winter
    Re: hi-flow cat vs testpipe...
    Sep 02 2005
    Montreal
    HFC = Maybe a very slight shift in power band, but no gains to speak of.
    TP = Anywhere from slight, to considerable gains and/or power shift. Depends on setup.
    Dec 06 2007
    ^^x2!
    -Kirk
    BetaAlphaTau Member #58
    Dec 25 2004
    Earth
    HFC=No CEL
    TP=CEL
    I have the HJS(Milltek) HFC on my K04 equipped with GIAC.
    Had a test pipe for 2 years. Loud, and constant resetting of the CEL. Plus I had to R&R the TP every year to pass state inspection!
    Bought the HFC, it flows as good as the test pipe, and mets emissions. No CEL, passes inspection, and reduced underhood heat and EGT's. The exhaust is no longer "loud" .
    Most people get the test pipe because it costs considrably less than the HFC.
    Depending on your ECU chip/flash, no CEL.
    Depending where you live, no state inspection.
    Registered Member Two Rings kyran A4's Avatar
    Feb 25 2008
    04 Quattro A4 1.8T
    Moorpark
    I have been wondering this too. I live in CA and my mechanic told me that the HFC is the way to go considering the whole not having to pay to get it taken out just to pass the smog inspection. he told me that the HFC is also better because the turbo doesn't lose the back pressure so that it keeps the already low amount of low end torque it has as opposed to the TP where it gains hp and sounds louder but loses low end torque. I also posted this question maybe a week ago and i got mixed answers, a lot of AZers love the TP from say euro code and such. I would love to see dyno numbers/ride in a couple of cars who have these setups.
    -my 2 cents ^_^
    -2004 silver A4 Quattro 1.8T-
    Debadged | RPM 502 18'' Hypersilver | Dunlop Sportmaxx tires | APR K04 | Audi TT 225 injectors | Magnaflow Exhaust | APR Software | ATP downpipe
    Future:
    Euro Code FMIC
    Tein H Springs
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    i had a HFC and ditched it for a test pipe wen i did my k04... i like no cats better.. get sweet gargling sound on downshifts..sometimes shoots lil flames, and sounds a lot throatier.. plus throttle response is great... to be honest pefformance diff between the 2 the TP prob gets you a little bit more power out of it not much tho.. if the CEL will bother you..go with a HFC tho my labree hfc threw a code anyways so it didnt make a diff... TP much cheaper tho.. i'd personally go with a TP
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    This is very dependent on your setup. What's your setup?
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    May 01 2008
    Winter
    Quote Originally Posted by RLB6 View Post
    Actually, I'm Unitronic stage 1+, Forge DV, K&N air panel.
    I'm going Unitronic stage 2, 380cc injectors, Milltek cat-back, Racetec FMIC,
    and 3" ER testpipe or HFC
    thank you!
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Hold on... Isnt apr 1+ or revo stage 2 (for example) suppose to erase the CEL from a testpipe forever?
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Sep 20 2006
    MD
    Quote Originally Posted by davidlizard View Post
    thank you!
    I'd say stay with a very low cell HFC, like a 200 cell Labree unit. BTW, Uni s/w has readiness built in for the 02 so you won't get a CEL.
    Sep 20 2006
    MD
    Quote Originally Posted by aaaudiprotein View Post
    Sure does.
    May 01 2008
    Winter
    I checked out the Labree website and the HFC for our car is very cheap (250$) compared to Milltek (800-1000$)... It's almost the same price that most testpipe... Is it a good quality?
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Sure does.
    Just from the dashboard or erase it so nobody can see that anymore?
    Sep 20 2006
    MD
    It's a solid unit and what I currently run. I went from a ER test pipe, (which I have for sale), to a HFC and I don't regret it.
    May 01 2008
    Winter
    Is the testpipe louder than the HFC??
    Sep 20 2006
    MD
    There's no such thing as just removing a CEL from a visual perspective unless you remove it's bulb/LED . So, yes, the s/w sets it readiness so that it doesn't report as a DTC.
    Sep 20 2006
    MD
    Yes but a HFC doesn't cut the volume in half unless you go with a higher celled HFC ( i.e., 400 or a 600 cell unit)
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I have a 200cell high flow cat and prefer it. The sound is just right (no raspy noises) and I'm doing fine with power. Plus the car doesn't smell like shit.
    -Doug
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    I've heard some people saying that their CEL lights was removed but they still had some problems during emission test or something like that.
    Feb 25 2008
    04 Quattro A4 1.8T
    Moorpark
    the hfc doesnt break any emmision regulations does it? I know the TP does.
    Future:
    Euro Code FMIC
    Tein H Springs
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    this is the HFC i am running on my setup:
    http://www.techtonicstuning.com/show...rtnum=253.167T
    Kyran, we have emission testing in New Hampshire and all the shop did was comment me on the sexy tone of my exhaust when i got inspected.
    i get a little bit of surfer smell when i really push it but that doesn't bother me.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    that picture is pretty dumb (and annoying) to be adding to every post. please stop that.
    -Doug
    Veteran Member Three Rings Gondi Stylez's Avatar
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    Does the Labree throw any CEL's? I need a new HFC and in Alberta there is no emmision's testing so that is not a concern.
    I'm going to be buying the Milltek exhaust so figured their HFC would be best - but $1000 for it YIKES!
    This is for a 3.0Q by the way
    '02 DG A4 3.0Q 6MT | Member of Club 3.0
    .:. OEM+ : Custom I.C.E : Vogtland GT : Hartmann : SPP : Hawk : Goodridge : JHM : Apikol : 034 .:.
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    I may be wrong but can't you just put a resistor on the O2 sensor thats on the TP to make it read the proper signal voltage so you don't get a CEL light? find out what the signal is at startup cold and warm and find out what resistor will take it down to that signal voltage...
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I think that idea has been tried with limited results, a simulator module of some kind, perhaps becuase of the varying readings that have to be met at different exhaust flow rates.. just thinking off the top of my head..
    Dec 19 2007
    York, PA
    anyway...theres a reason we cant have pics in our sigs
    Jun 13 2007
    Belmar,NJ
    labree is a good product but it did throw a cell on my car but didn't on my friends
    2003 a4... jus go with a test pipe if you don't mind the smell of gas and being a lil louder.. i like the smell haha :)
    Past cars:
    May 01 2008
    Winter
    I just email Labree and they dont have anymore 200 cell HFC. The expectacy of life of 200 cell was to short (6-12 month) So they now sell 400 cell HFC and they claims is just 2-3 hp less than 200 cell HFC.
    Is it a good buy? and also, How many cell is the stock cat???
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I have a Fast Insensions 300 cpsi metallic cat in my B5, same part fits the B6 tho. Car does not smell like ass but but did give a considerable power increase, if any. The stock cat flows well, but mine had over 100k on it so I just replaced it plus this one is easier to replace 02 sensors on.
    Its a turbo car, so if you want more power, change out the turbo (since that is your hp limiting factor).
    I had a diagram of a stock cat somewhere of the stock one and the metal casing has 2 metallic catalysts inside totaling over 1000 cpsi.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    The other advantage of not having a CAT would be the ability to use 120 Octane at the track. when I ran a catless MR2 AW11, I love running it on racing fuel, albeit, ten years ago it cost $5 a gallon, on wait that's what we pay for our crappy gas...LOL
    By the way, I've talked to a smog mechanic and they think that the state of California will be taking over the operations for testing, repairs, etc. Whereas a private shop will not be running the tests and repairs anymore but some public, bureaucratic State station that you will need to bring your car in for the certificate every two years. The guess is that owning the test equipment will be prohibitive very soon, with many shops investing Thousands on the current setup, which is only a 2-wheel model, in future state requirements, even our AWD cars will have to jump on the dyno and get a sniff of our exhausts while traveling at certain speeds and range.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    600-800 afaik.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    So is it worth going with Labree 400 HFC or skip that?
    May 01 2008
    Winter
    I think if you dont have smog test in your area, Go for the testpipe...
    Jun 15 2008
    Fairfield, CA
    Are there states/provinces that don't require a smog cert? In this day of age?
    USP Member 110
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    Quote Originally Posted by 04QuattroTurbo View Post
    Yep! Alberta!
    Canada FTW
    Established Member Two Rings 0000VW's Avatar
    Jan 10 2008
    2.0SOSLOW JETTA; 03 B6 A4
    North Carolina
    TESTPIPE BABY! know your car, put a testpipe on at a fraction of the cost of a HFC and don't be an idiot and sell it just keep it around for inspection time, the day before throw it on pass inspection. it's easy save the money for something else thats worth it
    Just keeping up with the rest of them...
