Results 1 to 12 of 12
    Jul 12 2008
    audi b6 avant
    Fredericton NB Canada
    another MBC question !
    hi guys, i'm new there and i've got a question !
    can i run a MBC alone with no other mod in my car to get 3-4 extra pounds of boost ?
    i've got an SRT-4 and i'm was able to pump up the boost from 14 psi (stock) to 19+ psi with out any mod. the computer was able to manage this extra boost just as a stock map !
    can my audi ca do that !? thank
    Sep 02 2005
    Montreal
    Re: another MBC question !
    Don't do that on stock software. Unless you like limp mode.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    i do it and it works great!! just be sure and have a boost gauge and vag com cause it takes some trial and error to set the boost controller so you wont hit limp. i spike to 12-13psi and itll hold around 10psi. its a little faster than stock and i havent had a problem yet, besides coilpacks.
    barrett
    2019 SQ5 Prestige
    Jul 12 2008
    audi b6 avant
    normaly it boost what ? 8 lbs ?
    why you need the vag com to do this ? to know how much boost your running ? if i use a boost gage do i need the vag com ?
    how did you hook you MBC ? where ?
    and are you manual ans tiptronic !?
    do you know at witch psi is the fuel cut for over boost ?
    thank for the info !
    Apr 01 2007
    houston texas
    8psi spike is stock
    you need vag com to get yourself out of limp bc you will hit it
    i unplugged the vacuum lines from the n75 and plugged them onto the mbc, leaving the n75 plugged in
    5 speed manual
    at 14 psi you hit limp, if you diode you can push it to 17-18psi on stock fueling.
    read this link here its got all the info you need to know...read through all the pages and you have a ton of info on the subject.
    http://www.audiforums.com/m_535568/tm.htm
    barrett
    2019 SQ5 Prestige
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by texasboy21 View Post
    8psi spike is stock
    5 speed manual
    barrett
    Stock boost is 11.5psi
    Apr 01 2007
    houston texas
    im mistaken must hold 8 pounds..my bad
    barrett
    2019 SQ5 Prestige
    Feb 17 2005
    Sarasota, FL
    barrett
    Maybe if you have a boost leak. The 150hp 1.8T's peak 9psi on a K03, the 180hp (or 170 for Audi) should peak 11.5 with the updated K03S. Either should hold damn near there intended boost and have no more than a 1-1.5psi drop. Chipped cars should peak 18-21psi and hold 14-15psi until the upper RPM's.
    To the OP, dont waste your time with a MBC, 2-3psi on the stock turbo's = 10hp gain. Your motor gains/loses more power with a 10-15 degree temp change ...
    Jul 12 2008
    audi b6 avant
    8psi spike is stock
    5 speed manual
    barrett
    AWESOME thank Barrett !!!
    Jul 12 2008
    audi b6 avant
    all right ...
    i run since few time, my turbosmart MBC and the diode mode.
    i've put my MBC between the N75 and the wastegate. (it plug on the good side)
    now, the thing is, i can't get a good setting for my boost.
    i would like to get 15 psi stable. so i try to set my MBC.
    so, this is what happen :
    when i push the gaz pedal, my bost goes up to 15 psi, and 1 or 2 sec later, drop back between 8 or 10 psi.
    i got the impression that my N75 do that. the MBC do it job, but at the moment the ECU see the new boost (15 psi) he ask to the N75 to put the boost back to the stock range (8 to 10 psi)
    i know a lot of dude are runing the MBC Like i do. but why there are not this problem ?
    do i need to plug my MBC alone and just bypass the N75 ???
    i already bypass my N249, and i got no vacuum leak (reading is 22-24 in-gh)
    let me know what you think guys !!!!
    NO, I'm not drunk or stupid. i'm from Canada and my first langage is FRENCH, so don't ask why my english suck so hard !!!!!
    Apr 01 2007
    houston texas
    run the mbc by itself. and just keep working with it less course boost more spike
    barrett
    2019 SQ5 Prestige
    Jul 12 2008
    audi b6 avant
    how ?
    take the in signal from the N75, plug it to the MBC and keep the out put from the MBC to the wastegate ?
    what do you do with your N75 ?
