Results 1 to 9 of 9
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    What does a knock sound like?
    I actually first noticed this sound during the heat of last summer but it's much more common now that I have my K04 installed. So what happens is I got WOT in 2nd or 3rd gear at about 2900rpms, I reach full boost and it holds and at about 3800-4000+ I hear knock knock knock, sounds kinda like belt slap so I let off the gas. I don't have a FMIC so is this sound engine knock cause by high IAT's?
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Re: What does a knock sound like?
    bump...do I need to supply more info?
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Like rocks in a can?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 08 2008
    Toronto, Canada
    Quote Originally Posted by dirtybrd View Post
    Bingo
    2002 Crystal Blue Metallic A4 1.8T Quattro
    2004 Black Volvo S60 2.5T AWD
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    i wouldnt run a K04 without upgraded intercooling unless you are somewhere with a mild summer
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Unfortunately that is not the case right now. It's been over 100 everyday when I leave work but I'm mostly just cruising on the freeway so it's ok. It definitely is knocking then so I'll just have to take it easy until I have the money for an FMIC. Is it serious enough that I should have the REVO dealer tune down my settings or can I drive it conservatively so it doesn't knock for now?
    Mar 11 2008
    B7RS4 & e46Ms
    you sir, need to do some data logging...
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    and post up your IATs so that I can have a laugh.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Jun 29 2007
    Raleigh, NC
    ^ditto
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
