Thread: Springs???
    Junior Member Two Rings LTrain2273's Avatar
    Apr 01 2008
    Minneapolis, MN
    Springs???
    I'm a noob to this so bear with me.
    I have the OEM sport suspension and I want to go LOW!
    I'm running 18" RS4 Reps with 235/40 rubber.
    I've been looking at springs (H&R, Eibach, etc.).
    I also looked at doing sway bars (H&R, Eibach, Neuspeed, etc.)
    I'm looking for better cornering without the teeth chattering ride quality as this is my DD.
    Any thoughts?
    Thanks in advance.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Springs???
    Stassis SS Coilovers and Hotchkins swaybars.. done
    Registered Member Three Rings Firefighter637's Avatar
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Re: Springs???
    Read this thread on springs: http://www.audizine.com/forum/showthread.php?t=219839
    As far as sway I installed the rear RS4 OEM sway and like it.
    A4 B6 1.8T USP Silver
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Apr 01 2008
    Minneapolis, MN
    Re: Springs???
    Thanks Gents, I think I'll wait for the PSS9's or Stasis SS's. Time to save up.
    Sep 02 2005
    Montreal
    Re: Springs???
    Quote Originally Posted by LTrain2273 View Post
    Any thoughts?
    Thanks in advance.
    Eibach springs are good but they're only as low as 02 sport, so basically a little lower than you are now, but probably not as "low" as you want. If you want to go lower, forget springs, invest in coilovers. It's worth it, even if you get a used set from the AZ classifieds.
