Results 1 to 2 of 2
Thread: N75 plug
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Question N75 plug
    is this supposed to plug completely flush? I couldn't push it in any further, and I got a "click" when i got it this far.
    shitty picture ftl
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: N75 plug
    can't really see the gap in the photo, a "snap" is bad, you might have broken the part that slides into the turbo inlet pipe, pull the N75 back out and make sure it's all still intact, you don't want to be sucking up part of it in your turbo unless you have money to throw away. all it comes down to is if the valve is not popping out then your ok. it's not rocket science, plug it in, tighten it down and check it after a day, if it's still on your all set.
