Results 1 to 3 of 3
Thread: CEL codes
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    CEL codes
    i got these codes; theyve been cleared and so far havent come back. around the same time i got a minimum oil light, i added a quart (oil change "kit" is in the mail).
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 8E0 909 518 AF
    Component and/or Version: 1.8L R4/5VT G 0003
    Software Coding: 0016701
    Work Shop Code: WSC 63351
    2 Faults Found:
    16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    P0011 - 002 - Lower Limit Exceeded - Intermittent
    16618 - Shareware Version. To Decode all DTCs
    P0234 - 001 - Please Register/Activate - Intermittent
    what do yall make of this??
    barrett
    2019 SQ5 Prestige
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Re: CEL codes
    From Bentley Manual:
    SAE VAG Description
    P0011 16395 "A" Camshaft Position - Timing Over-Advanced or System Performance Bank 1
    N205 - Camshaft Adjustment Valve 1
    Camshafts and camshaft adjuster removing and installing
    Overview of component locations
    Valve -1- for camshaft adjustment -N205- checking
    P0234
    16618
    Turbo/Super Charger Overboost Condition
    Apr 01 2007
    houston texas
    Re: CEL codes
    any other input?? whats going on here??
    barrett
    2019 SQ5 Prestige
