Results 1 to 7 of 7
    Established Member Two Rings Talon Load's Avatar
    Jun 23 2008
    '05 M3 Vert, '10 VW TDI Cup, '11 Grand Cherokee
    NC
    Need help, again
    So I'm starting to get the "I'm starting to regret buying this car blues" with another issue. At low speeds the left front makes a clicking sound, like something is knocking against the dust shield on the brakes. It stays till I get above 25 mph and then it seems to go away or when I put a load on the left front by weaving the car. I have been getting it pulling out of the drive way and parking spots the last couple of days. As the speeds go up it goes away and there are no vibes in the steering wheel at all. The brakes need to get replaced and parts go on order tonight. Could it part of that, maybe a bearing. Any help would be appreciated. I'm getting the car looked at next Thursday, but till then I want to make sure it's ok.
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    Re: Need help, again
    cv joint
    My car is fast
    Jun 23 2008
    NC
    Quote Originally Posted by IamEzraM View Post
    cv joint
    Great, is there any way to tell if it's the inner or outer? The sad part is that they guy that owned that car before me just that the CV boots done.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Is there grease in the wheel. When a CV bust you should find grease in the wheel.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Jun 23 2008
    NC
    Quote Originally Posted by RolledMySTi View Post
    No grease in the wheel, but there is some on the inside CV boot. I talked to the guys that just did the boot work and they said they " serviced" the CV joint and put the new boot on. It only does it at low speeds when I turn otherwise it's not there. I'm guessing it'll need a new inner CV boot unless someone knows of another option. The boots are less than two months old and look in good shape.
    Dec 06 2007
    Calgary, AB, Canada
    The clicking isn't from the boot being torn, it's from there not being any grease in the joint and the joint is "dry" and not well-lubricated. Try taking the half shaft out, taking off the inner boot clamp, push the boot back a bit, pack the joint with CV grease, and re-clamp the boot.
    Jun 05 2008
    00 s4/05 passat wagon
    turn your wheel all the way to the left and right and do many circle, fast, but no doughnut. this way you will push the grease into the joint.
