Results 1 to 9 of 9
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    How to stop Shifter movement?
    I hate how my shift knob moves up and down when I increase or decrease acceleration. I have a AWE DTS, but what else would I need to get rid of this problem? Would a power ring do anything?
    Veteran Member Four Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    Re: How to stop Shifter movement?
    my JHM shifter reduced this with approx 75% . I have the movement in only 2 gears now and not so drastic. before it was awful!!
    A3 8P DSG 3.2 S-Line : Billstein PSS / OZ Superleggera / 034 Sway / 034 Spherical bushes
    Dec 06 2007
    Calgary, AB, Canada
    New tranny mounts, the center diff mount.
    If you REALLY want to remove all slop from the drivetrain, do new engine mounts and snub mount as well.
    May 23 2008
    Columbia, SC
    I have a jhm shifter and snub mount too.
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    engine and tranny mounts.
    Buncha motorcycles
    Memphis, TN
    JHm shifter and 034 tranny/engine mounts, stopped mine 100%
    APR Stage 2/AWE Intake
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    034 Snub mount, 034 tranny mounts, 034 engine mounts, transmission stabilizer bar with poly mount upgrade, new center diff mount (apikol) or stern power ring, rear diff mount bushings (Pure MS) + JHM shifter = zero shifter movement. The combo brings some vibration into the cabin and breaks CV shafts when you launch hard too many times. . . and I love it.
    OR just start with what Jerbel said and that helps a ton.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Established Member Two Rings rick_chicago's Avatar
    Apr 29 2008
    B5 S4 (Stg 2), Honda CR-V
    Chicago (NW)
    Mine's roughly the equivalent of a soup ladle in medium-viscosity beef stew.
    I'm too busy enjoying the lack of a CEL to notice. ;)
    Stg 2 B5 S4
    Feb 17 2008
    Ottawa Ont.
    ive done ASP street density mounts all around, engine, tranny, rear diff, plus the rear diff mount bushings on the back plate, AAAAAND the jhm shifter, ANAAAAAAAND the DTS with the improved bushing...
    still waggles a bit on and off power. Much improved though.
