Results 1 to 14 of 14
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    relocating the cat converter
    Is it possible to relocate the cat. somewhere lower, like along the bottom of the car, with the sensors? I mean, I guess it can be done, but will it pass emission expection? If I can do this, it would make life so much easier with swapping the cat with a straight when emission time comes around.
    Also, will this hinder performance or make the ECU go koo-koo? (Then again, once I get rid of the cat, it won't matter)
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: relocating the cat converter
    It can be done. Has it? I do not know. I plan on doing this later, but that'll be in a year or so.
    You would have to extend the wires to the oxygen sensor and have a bung installed downstream from the cat. Otherwise if you have a "chip" with a catalytic converter efficiency code delete (most stage 1.5/1+) you can just make it look like it hooked up.
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    I have an AEb and my cat is mounted under the car, but then i dont need the 2nd oxy sensor like the later cars
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Feb 15 2008
    Sacramento, CA
    All right, cool. Thanks for the info. I plan on doing this also, just got to save up the money when I go all out on my car. Aiming for 350+ hp, 400 would be perfect. Trying to get rid of restriction as much as possible.
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    I had a HFC on my previous exhaust set-up mounted underneath the car with the o2 sensor right behind it. No check engine light and passed emissions.
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    I have a 99.5 which i'm assuming is still AEB cause its ndbw, i have 2 02's and what i think is a cat right behind my turbo.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Veteran Member Four Rings salz2135's Avatar
    Sep 15 2005
    Austin, TX
    he's from the UK though, so maybe the older AEBs didn't have the secondary 02 sensor.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by salz2135 View Post
    AEB is an OBD2 engine. Therefore it has the pre and post catalytic converter heated oxygen sensor.
    Sep 15 2005
    Austin, TX
    yes, thanks for telling me what OBD2 means.
    I misread his post and thought he wrote that the secondary 02 was nonexistent.
    Apr 22 2007
    Riverbank, Ca
    The SMOG guys only look for a cat, not that its in a certain location.
    The guy that I had smog mine last started under the car in the front, worked his way to the muffler when I told him its in the engine bay..
    Feb 15 2008
    Sacramento, CA
    Great info. This is very encouraging, makes me more persistent on saving those pennies to go all out for my mods.
    Jan 20 2005
    99 AJL TQS
    UK
    I only have one oxy sensor its located where my cat would be in a bung welded to the exhaust itself. No 2dn one, so i guess UK must have different regs then? Just for an O2 sensor pre cat, not after
    -Mark -
    Sep 15 2005
    Austin, TX
    so I did read correctly....
    Feb 13 2007
    98 A4
    Chicago
    Psh I don't need no stinking cat... I passed the air test without one.
