Results 1 to 29 of 29
    Veteran Member Four Rings m5racer's Avatar
    Nov 20 2006
    Ractec FMIC Install with Pics
    Hello all, so this past weekend with the help of Blake, i was able to install my Ractec FMIC. I must say install was pretty straight forward. It only took us a coupple of hours to get everything put on and done with. There were some small hitches in the install (like the intercooler sensor flange being put on the wrong side!) but most stuff was direct install. I must say after trimming my grills the FMIC fits behing the bumper no problem. The only issue im having is that the small mounting nubs are pushing down on my bumper, but im using the wrong mounting bracker (got proper one today) so i will show you guys some pics and then once i put the proper bracket on i will take some proper pictures.
    Enjoy:
    01.5 A4 1.8t sport
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Ractec FMIC Install with Pics
    You could always have someone remove the mounting nuts that are on the bottom of the fmic. They are only there for people that need to mount it upside down.
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    I did the same thing this weekend. I did the same stupid mistake with the sensor. for Racetec and Autobahn E. for the groupbuy.
    Nov 20 2006
    the sensor they jsut mount on the wrong side, its really stupid. Does it fit ur bumper or push it out like mine?
    01.5 A4 1.8t sport
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    looks like everyone decided to install the RaceTec this past weekend!
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Oct 20 2007
    ^ hahaha I guess so.
    M5racer: Yes mine does sag a bit but I just made minor trimming to adjust that.
    Here are my install pics:
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    Mine went on this weekend too. I wound up having to shave a lot of plastic around the bumper vents to get it to fit. Also i chopped off the lower mounting nub things with a hacksaw to keep the front valence from being pushed down. The vents had to go, there was no way they'd fit back on. But i like the way it looks without them so it's all good.
    {99.5 Avant}
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    so... it this going to be a "Does my intercooler look good thread?" or will someone post about the performance difference in hot weather with this nice IC?
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Senior Member Two Rings fenderstrat1184's Avatar
    Oct 17 2006
    '00 1.8tqm, '90 jeep cherokee
    northeast
    well i had some issues with my install (unfortunately i didn't give myself enough time to install it, and had to reassemble everything halfway through ><
    started at about 1pm in the hot sun (garage if full of crap and i had the day off, so what the hell)
    here's the kit sitting and waiting...
    finally got the bumper off (took me forever, mostly because i was afraid of breaking the clips etc, but now i can get that thing off in probably 5 minutes
    test fit to make sure everything is good before i start ripping out the old IC system....
    hmmm....
    how to get this
    through all of this???
    unfortunately that is where my patient wore out as i was out in the the dying and hungry with only another hour of spare time to work on this before i'd have to leave the house... so i packed everything back up and reassembled everything and i sit here an angry man.
    so how did you guys get around all those hoses and stuff... as you can see from the picture, it doesn't look like there is a clear path to get the piping though...
    (realize i'm pretty much a noob when it comes to this sort of thing)
    What's AOA? If Audiworld is the 1960's, AOA is 'the man.' Don't try to fight the man, because, just like the hippies, you'll lose.
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    whoah I thought you get to keep your stock grilles on after install?
    TEAM|AXION
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    fender, I am not sure about the racetec fmic, but YOU may have to re-locate that secondary air pump in order to get the piping to fit..(sec. air pump is the thing with the sensor going to it right behind the AC lines, if you don't know)
    Oct 17 2006
    northeast
    hmmm... any suggestions?
    Jul 07 2004
    socal
    Quote Originally Posted by speedydragon View Post
    Should, just need to trim the back of the grills.
    Quote Originally Posted by fenderstrat1184 View Post
    hmmm....
    Just push the pipe on in that position so that the pipe goes over your a/c lines and tucks up against the radiator support.
    Like this
    how to get this
    IIRC the tight bend should go toward the turbo while the smaller bend connects to the pipe that connets to the fmic. This will point the BPV port on the pipe toward the radiator.
    Here maybe this will help.
    I think Racetec might think about putting labels on each end of the pipes so people that haven't seen it done before know which order they go in.
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    ^^^ You have a 2000 so you have a secondary air pump on your passenger side which makes it difficult. The easiest way I found was to remove the entire SAP and then build the piping around the radiator bracket. You might have to hack the side of the radiator bracket a little bit but I'm not sure. I don't know exactly how the Racetek FMIC fits. I have an ebay one and the passenger side piping looks the exact same as the racetek. I buikt my piping and used a dremel and cut some of my radiator support and then the piping fit fine. I then installed the secondary air pump and it was kind of tight but it fit back the same way it was.
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
    Nov 21 2007
    The Sticks
    I'm confused what bracket on the radiator does the racetek FMIC go on? Some people have it on the top radiator mount and some have it on the bottom, that may be why it's difficult to manuver around you ac hoses and SAP.
    2001.5 1.8t
    Oct 17 2006
    northeast
    Audiluxary: thanks! i think i'm going to try that after my roadtrip this week
    Mike: THANKS. I swear, I'm more of a reader than a poster here (I only post after doing a fair amount of searching), and you ALWAYS help people out.
    Thanks again, I'll letcha all know how it works out, when I do this again on Sunday...
    Oct 17 2006
    northeast
    Quote Originally Posted by audiluxary View Post
    i just went off of pictures of docurley's setup... now that i think about it, it might make sense to put it on the upper bolt since, he has an oem rs4 bumper which sits lower than a stocker a4 iirc
    Jul 07 2004
    socal
    Most people put the bracket on the bottom holes. Fred2kA4 put it on the top holes because his AC had some funky fitting that got in the way from using the bottom holes. You can see it in the picture I posted, it is next to the bottom hole on the left side of the picture. He then used some spacer bolts to lower the FMIC down to where he needed it so that it would sit behind the opening of the RS4 type fmic.
    here is a better picture showing the a/c fitting that got in the way for fred.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    damn people are puttin on racetecs like crazy.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Oct 22 2006
    whats so special about these racetecs? why not just save money and get a ebay special
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by karmad View Post
    Because there was an AZ group buy and now everyone is finally receiving them.
    -Doug
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    We still have some B5 A4 Racetec intercoolers in stock. PM me for that group buy price if you may be interested!
    Nov 20 2006
    Alright Fenderstart this is wha you do. You have to actaully cut a small piece of the plastic that is in the way in order to fit the FMIC in properly. DO NOT RELOCATE THE SECONDARY AIR PUMP! as it is not nesseary and you should not do it. all you have to do is cut a small pice of the support and it will wrap around just fine. The piece you cut has no structural signifiance and serves no purpose.
    And yes the stock grills fit jsut fine, you just need to trim the back of them. I trimmed mine and they fit/look like stock now.
    01.5 A4 1.8t sport
    Oct 20 2007
    I didnt do any bending. I just loosed the the a/c unit and the smog thingymajig and pushed it out of the way.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    - m5racer
    I'll take a look at your racetek at WF and I might pick one up as well.
    Registered Member Two Rings
    Jul 06 2008
    2001 Audi A4 1.8T
    That means it won't fit with the stock bumper?
    Aug 11 2007
    California
    It does fit with the stock bumper.
    Jul 06 2008
    2001 Audi A4 1.8T
    But it seems to be too big in m5racer's pix.
    Jul 07 2004
    socal
    Quote Originally Posted by hawaii View Post
    Its just the bottom mouting tabs on the FMIC that are causing the valance to be pushed down.
