Results 1 to 7 of 7
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Unhappy i did something dumb..
    started the car with the n75 unplugged.. oops
    now I have a CEL, car stutters before boosting, spike and hold at 7psi.
    My question is, did I just put it into limp mode? And anybody know if autozone can clear limp mode with their scanner?
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Jun 30 2007
    Raleigh, NC
    Re: i did something dumb..
    plug everything back in - disconnect the batter - wait - reconnect - start up code free
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Feb 24 2007
    Burlington, Vermont
    sorry, tried that already. had it unplugged for an hour. Does it at least sound like limp mode?
    - Scott
    Das Build Thread
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    when you say unplugged N75, do you mean ONLY the electronic part, or do you mean you disconnected the vacuum hoses?
    If the latter, you may have put it back in wrong.
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
    Veteran Member Three Rings kpatz's Avatar
    Nov 08 2006
    '02 Audi A4 B6, '06 Mazda6 wgn
    NH
    Having the N75 electrically disconnected causes "limp mode" but not in the usual sense. Instead of the ECU limiting boost due to a problem, you disconnected the valve the ECU uses to control the boost in the first place. In other words, the ECU can no longer increase boost because you disconnected the N75, thus you'll only get about 7 psi. You'll get a CEL due to the open circuit code.
    Once you plug everything back in you should get boost back. The CEL will go away on its own after a few driving cycles, or you can disconnect the battery or use a code reader or VAG-COM to clear the code.
    2002 A4 1.8T Quattro, 5 Speed, Goodwood Green (rare color!)
    Current mods: APR Stage 1+, TT225, 710N, APR Snub, JH solid short-throw shifter, JH solid linkage upgrade, Sachs clutch, Euro shift knob/boot, 4300K HID D2S, 18" VMR RS4 reps w/General Exclaim UHP, hardwired Valentine 1 w/remote display
    Feb 24 2007
    Burlington, Vermont
    well I just went for a drive and boosted 3 psi max. pretty sure i plugged the n75 back in, unless you really need to squeeze the fuck out of it to get it on. heres my drawing of how i installed it, since i dont want to take a picture
    - Scott
    Das Build Thread
    Feb 24 2007
    Burlington, Vermont
    i guess the "to wherever" would be my wastegate, right?
    - Scott
    Das Build Thread
