Results 1 to 9 of 9
Thread: Wheel Spacer ?
    Registered Member Two Rings
    Feb 12 2008
    A4 2.0T Q- Ocean Blue Opearl
    Wayne, New Jersey
    Wheel Spacer ?
    I have the 18' sline wheels on my car lowered and i want to get spacers ..What size are peopel running with these rims and will i need to get new bolts .As well as from what company. Thans again
    Veteran Member Three Rings Kschroers1's Avatar
    Jan 12 2008
    17' Jeep Grand Cherokee Limited 1942 Edition, 12' A4 Premium S-Line 6spd Quattro
    Roanoke, VA
    Re: Wheel Spacer ?
    H&R make's a really good set for around 90 bucks. I used 15MM on my stocks with 43mm length bolts. I only used them on the rear. But people around here at putting 5mm, 8mm, and 10mm on the fronts and 15mm max on the rears i think.
    Feb 12 2008
    Wayne, New Jersey
    Re: Wheel Spacer ?
    u are using 15 mm spacer on a 18 in wheel iin the rear?
    Jan 12 2008
    Roanoke, VA
    Re: Wheel Spacer ?
    I was using them on my 17's but since i got 19's i took them off. But their are people around here using 15mm spacers. You wont rub. i promise.
    Nov 12 2007
    Grand Junction, CO
    Re: Wheel Spacer ?
    I have 15mm on the rear and just ordered 8mm for the fronts.
    May 19 2008
    PA
    Re: Wheel Spacer ?
    Hey guys, I heard a few horror stories about spacers cracking and stuff like that, I want to get them but worried about going on a long trip and having something happen. Is the set from H&R better than what I've heard? Anyone? Thanks
    Jan 12 2008
    Roanoke, VA
    Re: Wheel Spacer ?
    H&R are well worth the money since their around 90bucks a pair. I think their aluminum, cant remember, you may want to check the site. Their hubcentric, and as long as you tighten the wheels to spec, nothing will ever happen to them. Have the correct size bolts and correct tightening specs and you'll be fine.
    Jun 25 2008
    2006 A4 2.0T S-Line Tip
    Nashville, TN
    Re: Wheel Spacer ?
    H&R hubcentric spacers are the way to go. 12 mm on front, 15 mm on rear. make sure you get new bolts.
    i have the 18" sline OEM wheels.
    2006 A4 2.0T S-Line Tiptronic / APR Snub / RS4 Sway / VMR Boost Gauge / Hoen Fogs / Quantum 14% Tint / Painted Reflectors / Clear Corners / Dice Electronics I-Pod / Valentine 1 Hard Wire
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
