Results 1 to 13 of 13
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    spark plug pic. too lean?
    im running BKR7E gapped at .022. the car at 24 psi will run great until it gets hot. then it starts to miss. if at that time i turn it down to 20 psi it runs great again. if i open the gap the car will hesitate all the way down to 15 psi. also the car has a strong fuel smell sometimes. i feel like i have this narrowed down to a plug problem. also the tune i have is a EPL tune but the shop that was helping try and find this problem 2 months ago had said it was running a little rich so they had EPL send a different tune. i think now i just need to get their OTS tune again and run a colder plug?? these look pretty lean to me.
    Apr 05 2007
    Re: spark plug pic. too lean?
    they look pretty white.
    should be more tan like the nice pair in the second pic - perfect focus, BTW..haha..
    also - any ECUx logs to see what your knock voltages, timing CF's and o2v's look like?
    Nov 13 2007
    denver
    Quote Originally Posted by volks88 View Post
    Check blocks 15 and 16 with VAG and see what cylinders the missfires occur. Is it all six cylinders? Could be a ICM issue. My bad ICM missfires got worse as the car warmed up.
    May 06 2007
    Quote Originally Posted by audidweeb View Post
    3,4 & 5 at idle. all 6 cylinders when it hesitates at WOT. if i turn boost down in to a "safe zone" like under 20 psi i can drive without throwing a CEL and hammer on the car.
    Quote Originally Posted by exorcet View Post
    yeah haha i was like " this ones for the boys on audizine" lol
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    they actually look fine to me.
    electrodes are supposed to be somewhat white.. but if the white starts creepin up the threads then you have issues.
    mine misfired when it was hot too.. ended up just replacing all 6 coils.. misfires went away for good
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Dec 06 2007
    Calgary, AB, Canada
    Try cooler plugs man.
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    I cant clearly see the pair in the 2nd picture, different angle might help =)
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    Whats cooler than a NGK BKR7E11 that would work well? Im running FDR platninums and am thinking I need a cooler plug with a tighter gap..
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    what spark plugs?
    May 06 2007
    Quote Originally Posted by Boris View Post
    the next colder plug i believe is the BKR8E-IX. if my understanding is correct with a colder plug you could run a bigger gap. i could be wrong but ive read more about plugs the last 3 days than i have in my life lol
    Feb 17 2008
    Ottawa Ont.
    I run those plugs gapped to .026 works well.
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    milf
    My car is fast
    Senior Member Two Rings quickdub's Avatar
    Jul 06 2005
    1973 Mustang Conv.
    CA/NJ
    Try Denso Iridiums... I've been using them on my turbo VW/Audi cars for over 5 yrs now, and I swear by them. They don't need replacement nearly as often either.
    Worth the extra $$ if you ask me.
    New Coils, rubber boots & Denso plugs cured all my misfire issues.
