Results 1 to 9 of 9
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Need insight on adjusting wastegate actuator
    Hello. I need help on adjusting my actuator. It all started with my car having a blown one and my dad decided to change it himself with my grandpa helping him. It seems that they didn't quite put it on right since I can't boost past 11psi. I even got a MBC but that still didn't help.
    My question is whether anyone knows how it is supposed to be adjusted. I know that it has a nut on the end of the arm that determines how much the wastegate will open. Are there any measurements/how much threads it is supposed to be set on? Also, will my way of unbolting the exhaust at the cat work to reach the actuator? Thanks
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Apr 22 2007
    2010 Audi A3 2.0T Quattro Prem+
    Boston, Mass
    Re: Need insight on adjusting wastegate actuator
    Oh boy, I just got mine replaced with a K04. When you say a blown turbo. Do you mean the seals on the turbo went or did the turbo stop spooling? What kind of turbo did you replace it with?
    Couple of things you can check is for boost leaks, spark plugs, check your hose clamps on the charged side. Basically check for any positive pressure related issues as these could leak boost. Giving you such problems.
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Quote Originally Posted by Ayefore View Post
    No, the turbo never blew, still the stock K03 as I continue saving for BT.. The actuator went bad. The car was diagnosed by a very reputable shop (Renn-Art) and no boost leaks were found. I am almost positive that its the actuator that is misaligned and not letting the wg close fully.
    Soon to be BT...
    Apr 22 2007
    Boston, Mass
    Hm.. In that case then check your plugs, and n75 maybe.
    But if you must know. Here's a couple of good links.
    http://golfmk5.com/forums/showthread...ight=wastegate
    http://forums.vwvortex.com/zerothread?id=3932086
    Lucky our cars are kinda easy to get that. I suggest doing short 1 thread turns to see.
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    How is your MBC set up?
    I'm assuming since you were able to pull your turbo out, you know how to correctly use an MBC?
    (figured I'd ask, I've never seen you post, and you're only a 2ring member)
    ÖMGHI2Ü
    Photography
    Apr 22 2007
    Boston, Mass
    I don't need to post up here since this place has all the info I need. =) I like to help once in a while. I don't use a MBC but basically it should be hooked up parallel to the n75 so that all it does is purge of spiking. I have another link to that as well.
    http://www.audizine.com/forum/showth...&highlight=MBC
    PS: I really think you should really consider checking other stuff out before "cranking" your WG.
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Quote Originally Posted by Yaktizzle417 View Post
    I really don't think that it has anything to do with the MBC or the N75 since both give the same boost. Even when I disconnect the vacuum line from the actuator, its still only 11 psi..
    Soon to be BT...
    Apr 22 2007
    Boston, Mass
    HM.. I believe you could be on to something here. I would proceed with the adjustment and see what you get. if you dont see any change. Then I'd suspect your WG is broken or it could be caught on rust and stopping it from closing.
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    No, definitely not broken. As I stated, it has been changed.. Just might have been put in wrong.
    Soon to be BT...
