Results 1 to 7 of 7
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Price Check Request
    I'm not posting in this section, but my friend is considering to get 2001 A6 with 100k miles. It's a 4.2.
    I run vag-com on it and was clean except for the engine:
    Address 01: Engine Labels: None
    Part No: 4D0 907 560 AE
    Component: 4.2l V8/5V G 0001
    Coding: 07752
    Shop #: WSC 02325
    WAUZL54B41N071730 AUZ7Z0Y1622006
    5 Faults Found:
    16826 - EVAP Emission Control Sys: Small Leak
    P0442 - 35-10 - - - Intermittent
    17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
    P1131 - 35-10 - - - Intermittent
    16825 - EVAP Emission Control Sys: Incorrect Flow
    P0441 - 35-10 - - - Intermittent
    17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
    P1411 - 35-10 - - - Intermittent
    16706 - Engine Speed Sensor (G28): No Signal
    P0322 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    It has a weird pull to it, shot suspension, and a minor exterior damage. Heated seats, both memory seats, leather, xenons, shades. Seller states that it has OE radar detector which I think is BS (he saw audi logo on it somewhere under a bumper).
    He also claims to have a timing belt parts and monroe shocks in the trunk and parts cost around $2k. I don't think it is reliable information.
    Hopefully somebody here can give me some good insight and also what else is good to look for.
    He asks for $9,000.
    What you think?
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Re: Price Check Request
    priced too high imo... especially with all those probs and potential for headaches
    4.2/V8s aren't too hot on the market either because of the whole gas issue so surely you can wait it out for a better deal
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Apr 18 2007
    ny
    offer 5k, that sounds better to me.
    Veteran Member Three Rings 04A6SLine's Avatar
    Oct 16 2007
    Brooklyn NY
    wait awhile or offer him 7000..
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    Too high and I would not take the timing belt parts. Buy those from a trusted seller, as there have been many, many instances of the tensioner bolt shearing and destrying the engine. Either there was a bad batch of bolts or a bunch of cheapo knockoff parts.
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Feb 12 2007
    2001 Audi A6 4.2 (sold), 2010 Q5 3.2 (sold), 2008 Lexus IS250 AWD, 2011 Lexus RX350 AWD
    Unknown, AK
    No.
    Not even worth $5000.
    Consider that what needs repair will cost almost, if not more than the selling price, rethink that you're buying an 8 year old car for about $9 + $9= $18k.
    You should be able to buy a 2001 A6 4.2 w/ 100k for about $12k...and we're talking great running condition, with no major exterior or interior deficiencies.
    Monroe Shocks? OE Radar Detector?
    I'd move on from this deal. Sorry.
    Sep 14 2007
    Valley Stream, NY
    I thought so, thank you very much.
