Ok, flamesuite on - I know most of you guys don't buy into these kinds of products, but working on promoting my site. Will be doing a solid write up once I get the GTi to the dyno...
Like everyone, I like to tune my vehicles with aftermarket performance parts. To that end, I like to take the route of performance based efficiency. So with so many mods on my GTi which speak to that measure, I was curious about a new product on the market called "Pulstar plugs". They use a unique design which reminds me of a similar concept of performance wires that I installed from Nology on my VR6 Corrado. They use capacitors to help increase the amount of electricity being sent to the spark plug.
Today because of coil pack based ignition systems, you don't have spark plug wires, so what does one do when they want to increase the performance of the ignition system? Well basically you only had one option until today, buy a fully custom solution which is very expensive and complicated to achieve. The Pulstar plugs build on this methodology (Nology) and place the capacitor in the spark plug itself. A novel and creative way to get this type of ignition enhancing technology into the 21st century.
So I contact Pulstar and got a couple of sets for my vehicles... I installed the first set on my wifes Audi A4 1.8T Avant (quattro). A heavy vehicle with drive train loss due to the all wheel drive system. I have had several recent trips mainly highway where I have watched the fuel economy to be an average of 28-30 MPG. So it is a good test bed to try and see if these plugs could make a difference. Another aspect to these plugs, going back to the performance factor here is a note from their web site: "Pulse plugs have 10 times more peak power than spark plugs and ultimately improve the performance of your vehicle as well as the performance of all aftermarket performance products. Pulse plugs simply ignite fuel better and should be the very first step in improving your engine's performance."
So I was excited to see what the results would be... I installed the plugs and per the instructions, it can take up to 2 hours of driving or approximately 200 miles for the ECU to make adjustments before "real" improvements are known.
Once I fired up the car, I immediately noticed a smother running engine. Everyone knows the 1.8Turbo engine is not exactly buttery smooth, but I did notice an increased smooth idle. Cruzzing down the road, I also noticed and increase in throttle response and overall the engine seemed to pull better by the seat of the pants dyno. I reset my MFA and trip odometer to start to see what kind of economy I was getting when I filled up with fresh 93 octane from Shell. At the end of the tank and going down the highway on an average of 70mph I got an average of 31MPG. On the way back from my trip, I followed the same procedure and saw an increase to 33MPG.
Now that does not sound like a huge change but if you run the numbers it is rather significant. I am excited to see how the car does going forward... I also have another set to install in my GTi- however I am waiting for a day off to take my car to a local shop which has a dyno. I will be doing a write up on the dyno experience by setting a baseline with the factory fresh OEM plugs and then installing the Pulstar plugs and doing another pull.
Keep in mind if you are highly modified the company does not recommend using these plugs as they will be to hot for your application...
Will let you know what the outcome is soon!
Link to Pulstar
http://www.pulstarplug.com/
