Results 1 to 8 of 8
    Veteran Member Two Rings Bogs288's Avatar
    Apr 02 2005
    1992 GMC Typhoon
    victor, NY
    Vibration under braking???????
    Anyone got any ideas as to what could be causing my steering wheel to shake when im braking. When i'm driving, everything is fine, it's only when braking. I installed a 355mm brembo kit a couple months ago, and everything has been fine. I took everything apart and retorqued. Can't find anything that could be the cause. Any ideas???
    2002 S4
    1992 GMC Typhoon
    A bunch of mods. I don't like to brag.
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    Re: Vibration under braking???????
    could be a warped rotor or the rotor could be on backwards
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Veteran Member Four Rings jefferson88's Avatar
    Feb 12 2004
    08 A3 2.0T S-Line
    G-town, Ontario
    I had the same issue, I used a screw driver to clean the slots out (dust built up in winter).... They were fine after that.
    Past: 99.5 A4 1.8TQ, 07 A3 2.0T
    Present: 09 A4 Avant 2.0T & 08 A3 2.0T S-Line
    Apr 02 2005
    1992 GMC Typhoon
    victor, NY
    That's interesting, ill have to check that out.
    2002 S4
    1992 GMC Typhoon
    Established Member Two Rings Talon Load's Avatar
    Jun 23 2008
    '05 M3 Vert, '10 VW TDI Cup, '11 Grand Cherokee
    NC
    Also check you pads if you've had them on for a while. I just went through this with another car and the rotors and pads were gone.
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    Quote Originally Posted by Bogs288 View Post
    Out of curiosity, what wheels are you running and any pics of the bbk?
    Apr 02 2005
    1992 GMC Typhoon
    victor, NY
    running DTM kruez 10 spokes. been meaning to get some pics as soon as i can get a chance to wash the car.
    2002 S4
    1992 GMC Typhoon
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    could be a control arm bushing going out
