Results 1 to 10 of 10
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    Cant I just solder up my own rear plate LEDs?
    Can I just solder a few LEDs from the shack to the shitty 97+ bulb holders with some transistors in line to allow for the 14v?
    Im not too cheap for the 39mm draft designs bulbs, just looking for something I can do myself for a fraction of the cost if possible. I have this week off of work and dont have anything to keep busy.
    Why hasnt anyone else done it yet?
    Self made, NOT Mommy paid.
    2001 1.8 qtm, GT2781R, 680cc Siemens, 3" turbo back, Autopower, Mafless Stage 3 Unitronics, Tial 38mm external wastegate, STS, Corbeau seats
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Re: Cant I just solder up my own rear plate LEDs?
    Don't you mean resistor? A transistor either acts as a switch or an amplifier... A resistor drops voltage via converting that voltage into heat...
    ΜΟΛΩΝ ΛΑΒΕ
    Jun 12 2008
    Allentown PA
    Dont I want to bump a 12v LED UP to 14v?
    IE: transistor?
    IDK about electronics lol
    Mar 04 2007
    nothing
    nowhere
    Emmmm, no... If you have a 12V LED just plug it in...
    ΜΟΛΩΝ ΛΑΒΕ
    Jun 12 2008
    Allentown PA
    But I thought the VW/Audi rear license plate bulbs were 14v? Not 12v.
    Mar 04 2007
    nothing
    nowhere
    12V and 14V are basically the same... Automotive systems are commonly refered to as "12V systems" though the alternator charges at 14V...
    ΜΟΛΩΝ ΛΑΒΕ
    Jun 12 2008
    Allentown PA
    Huh, I thought I read here that using the 12v LEDs would lead to burnt out diodes quickly......
    Hence the reason 42 draft designs sells 14v specific units.
    Mar 04 2007
    nothing
    nowhere
    Where did you read that from? I have run plenty of 12V LEDs in VW's/Audi's and never had one burn out... One example is my 97 Jetta where I converted the green lights in the interior to red and put in some blue indiglo gauge covers... Looked nice! Better than the MkIV's IMO but that was the look I was going for... I used 12V red LED's everywhere except the window switches which I had to use a slightly smaller LED which those DID need resistors since they were rated at 3V...
    ΜΟΛΩΝ ΛΑΒΕ
    Sep 11 2007
    Dirty Jersey
    the 42 draft designs leds are 14.5 v, because their original 12v design was burning out fast in mk4 aplications, so they gave themselves a factor of saftey in their new units
    car electrical systems can be anywhere from 10 to 16V, if you get some quality leds you can make your own, but honestly I might just pick a set up
    I installed my 42 draft desin ones the other day and they are nice, however the light isn't even due to the way the grab handle is over the plate tub
    Nine [O_O] Eight Tuning
    custom work, fabrication, bumper shaving, fender rolling, plastic & fiberglass fabrication and repair
    Turbo charged and lowered for better grocery getting :screwy:
    Veteran Member Four Rings m5racer's Avatar
    Nov 20 2006
    i have 12v in for over a month now and no problems at all. also i find the 42 draft bulbs to be to bright. Oh and if you look at the stock bulbs (in my 01 at least) they are 12v not 14v. I know this beucase i repalced mine with stock first then led a few days after.
    01.5 A4 1.8t sport
