My driver side turbo started whining, then screeching, then smoking (on the outside, not through the tailpipe, weird).
Hello K04's for $2135, inlets for $375 (used), motor mounts because someone messed up one of my repairs and they broke, ($45 used) and a set of RS4 intercoolers with APR pipes, plus I have an APR Y pipe I will be putting in. I already had a Milltek 3" cat back installed.
Labor is $1,000 and my audi tech at the dealer is doing it in my garage. He will be supplying the gaskets and a new set of stock plugs at his 30% discount from the dealer.
My question is can I run the Unitronic software I had on before my turbos failed, or do I really need to flash it again and get a new set of injectors and an FPR like Unitronic tells me? Also, are stock injectors what I need or should I throw down for something else?
My goal is not to create loads of power at this point; I will buy a flash, injectors, and another FPR when it's time. Now I want my car driving again. However, I don't want to lean it out and toast my heads.
I did a few searches for this info but maybe I was looking for the wrong words and phrases, I actually looked for nearly an hour last night. If I missed something don't flame me for not knowing where the search button is, flame me for not knowing how to search or whatever.
Any help will be greatly appreciated.
