Results 1 to 15 of 15
    Senior Member Two Rings ekaufman's Avatar
    Jul 02 2007
    2008 Black A4 S-line
    Santa Monica
    Can you put springs only on the front?
    I was considering the conservative drop of the Eibach springs on my non-quattro B7, but after putting my wheels on with a 35mm offset, the rear fender is filled nicely on the stock sport suspension. However, the front is still a little high for my taste. I havent come across another thread talking about it, but can you put lowering springs on just the front of your vehicle to even the gaps?
    Before you explain to me how coilovers are a better option, and how springs can wear out the stock shocks; dont sweat it, I already know.
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    Re: Can you put springs only on the front?
    Yes, of course you can. Nothing is stopping you from doing what you want. Is it a good idea? Not particularly. It will upset your car's handling causing it to understeer more, which is already a problem on our cars, but if you don't drive it hard there's nothing to worry about.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Jul 02 2007
    Santa Monica
    Thanks for the info. So youre basically saying that a stiffer front suspension would cause handling issues?
    Anyone else have any experience with this?
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    I have seen anyone sell just 2 springs for our cars! why not just do all 4 and be happier with the front and rear?
    The usual things!!
    Resistor Install
    Jul 02 2007
    Santa Monica
    I wanted to even it out a little. Im happy with the rear as is. I'll probably end up doing all 4, I was just exploring some other options.
    Active Member Four Rings marty was here's Avatar
    Nov 10 2006
    992TTS 992GT3 RS7
    nnj
    Quote Originally Posted by ekaufman View Post
    coilovers and lower it different heights?
    We have a black president... Racism is dead.
    -JPT
    I have a real sore throat...feels like I've been deepthroating gorillas.
    mister_tu
    Hey, I just read this (and this is crazy), but take your two cents, and fuck off maybe?.
    audia
    Nov 12 2007
    Grand Junction, CO
    well...w/ the stasis street sport coils, the preset settings have the rears about 1/8 of an inch higher than the front.
    Veteran Member Four Rings MAlby7's Avatar
    2017 Infiniti Q50S (HIS), 2014 Nissan Rogue (Hers)
    Woodbridge
    I also can't stand how are cars are higher in the front. Unfortunately I cannot afford coilovers now that I'm getting married so I learned to live with it the way it is. Either do it right or don't do it at all.
    Senior Member Three Rings jejeclown's Avatar
    May 22 2008
    Carrera4S-dad LS460L-mom A4-me
    ny
    Quote Originally Posted by malby7 View Post
    either Do It Right Or Don't Do It At All.
    +1
    08 Audi A4 2.0T S-line Titanium pkg., Quattro, SE pkg. , convenience pkg., nav, tip, Phantom Black on black.
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    If you alter just the front your going to have different spring rates in the front compared to the rear and your car is going to ride like a clown car IMO.
    Like malby said, do it right or don't do it at all.
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Jul 02 2007
    Santa Monica
    Quote Originally Posted by AudiWxGuy View Post
    The Stasis set up has the rears higher? Audi, along with most other manufacturers, has the front suspension a little higher, so Im surprised to hear that the Statis set up does the reverse.
    Nov 12 2007
    Grand Junction, CO
    That's what the instructions state. However, I'm having mine adjusted to 25" all around
    Stage 3 Forum Advertiser Four Rings VMRSport's Avatar
    Apr 25 2008
    Irvine
    I wouldn't do it. Your car will look and handle weird. Depending on how much it is lowered, and what kind of springs/rates.
    This box does not currently receive PM's. Please direct all inquiries to Charles (VMRWheels) or Peter (Peter@VMRWheels).
    B5/B6 Audi A4 Test Pipe w/ Heat Shield
    VMR Sport | Integrated Vent Gauge Kit
    B7 Audi A4 Test Pipe - $69.99
    Senior Member Two Rings jayM's Avatar
    Jun 29 2007
    like the above have already said, do it right or don't do it at all.
    Most if not all aftermarket spring manufacturers have a smaller drop for the rear springs (thus creating an even drop in the front and rear). honestly it doesn't make much sense only having lowering springs in the front.
    2012 Mercedes-Benz C350 4matic Sedan
    2006 Audi A4 2.0t quattro - Sold
    Vancouver, Canada
    Jul 02 2007
    Santa Monica
    Quote Originally Posted by VMRSport View Post
    I was goign to go with the more conservative Eibach Pro Kit that lists an even 1.2" drop for both front and back. On the sport suspension, it will only be about 0.5", but it will still be uneven. I think Im just going to have to live with it, unless I go with coilovers.
    Thanks for all the info/advise.
