Results 1 to 11 of 11
    Registered Member Two Rings zims666's Avatar
    Apr 17 2008
    '05 A4 B6 1.8t 6speed
    Chapel Hill, NC
    DIY: B6 A4 - Remove & Polish Intake Manifold
    i searched FOR EVER on this topic, and finally found it on a site I look at daily (after i gave up searching.)
    http://www.a4mods.com/index.php?page...emanifold.html
    im planning on pulling my intake manifold to polish it.
    heres more info/help on polishing intakes:
    http://www.audiworld.com/tech/eng72.shtml
    http://www.dubnetworks.net/showthread.php?t=1254
    good luck, have fun
    Jun 07 2013
    UK/NZ!
    [like]
    thanks for sharing
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Just an FYI polished aluminum does not disperse heat very well and is more prone to heat soak. Both of which have very negative affects on IATs and being this a turbo'd car not the best idea. Unless you only care about the looks then go for it.
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Dec 19 2007
    York, PA
    interesting claim....any proof?
    Feb 05 2014
    I work for an Engineering firm and we deal with heat transfer on a daily basis and also this Study
    Feb 05 2014
    In short when you polish aluminum you have removed surface area. More Surface area = more cooling. Its just like adding a larger intercooler.
    Dec 19 2007
    York, PA
    makes sense
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    I did something like that, this is what I ended up with.
    I have a GTRS with a good FMIC my IA temps stay in check.
    Its a bit of work just keep at it.
    SOLD the GOINHAM A4 ---> GT2860 Project
    Veteran Member Three Rings Waspjr's Avatar
    Feb 03 2013
    Wifes jacked up f350 on 24's custom paint job landrover lr3
    Osoyoos/bc/canada
    Heat dispersant turbine ceramic paint is nice. You do need an oven for the cure tho
    Altho i am a sucker for shiny stuff nice work (up)
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    ^ I like that.
    2019 SQ5 Prestige
    Feb 05 2014
    Both are pretty nice. I'm going to get that black ceramic powder coating that disperses heat on my FMIC and Intake.
