Results 1 to 11 of 11
Thread: Alignment
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Alignment
    My suspension was installed a month ago and i still havent done the alignment.
    I was about to it this week. But i still have that high sqeeuzyy noise everytime i go over something or even feel the struts sometimes... So im thinking that might be my stock bumpstocks.
    So can i do the alignment before i cut the bumpstocks/or if id have to take the suspension apart?
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Jun 13 2008
    Bay Area
    Re: Alignment
    i think you should cut the bumpstops first, cuz then you would have to take your suspension apart again after the alignment and your alignment will be off ocne again...
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    Re: Alignment
    I agree. Cut those bump stops, make sure that is your issue, and then do the alignment. Keeps the steps taken to a min..
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: Alignment
    Trust me you will regret not getting an alignment. My brand new tires are shot, because of my ignorance to getting an alignment.
    -Sami-
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: Alignment
    ^^^ i want to do an alignment, i just need to find out whats going on with my suspenison first.
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    Re: Alignment
    I guess sport suspensions probably all require sport bumpstops. Is that what you have? I had non-sport suspension so when I upgraded to Stasis SS the instructions specified to cut them 1 inch. I guess you need that.
    When I went in for an alignment, I needed some toe adjustment but that probably didn't come from the suspension install. My mechanic said he didn't touch the bolts that are responsible for that part. The camber cannot be adjusted in front anyway so there's no rush. It's dependent on your ride height unless you buy adjustable plates or something.
    For reference, I'm riding at 25" front 25 1/8" rear and have -1,5° camber in front and -1,0° in rear.
    FXK03 - Stasis SS Coilovers - Forge DV - Forge TIP
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    Re: Alignment
    you can always order new stop bumps for the sport suspension online. I did that when I put in my coilover
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: Alignment
    I used to have base suspension- now i got race springs. I used stock bumpstops. But i dunno anymore if they are my problem.
    I described my problem in a first post- anyone got any comments?
    Also, can i just rally cut the stock bumpstops one inch?
    May 03 2007
    german
    heaven/hell
    Re: Alignment
    I prefer you buy sport suspension bump stops instead of cutting your base suspension bump stops.
    then yes, do the bump stops first and then alignment
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: Alignment
    Quicky
    Is alignment recommended after the wheel spacers installed?
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: Alignment
    Try having a car that can't be aligned!
    -Darrick
