I changed out the valve cover gaskets and the cam chain tensioner gaskets using the kit found here:
http://blauparts.com/proddetail.asp?prod=GF21002
I installed everything using the tech article found on AW. I put some of the provided loctite on various parts of the gasket and also made sure the position of the cam chain was correct. I cranked it up and everything sounded fine. I took it for a spin around the block and parked it. popped the hood and noticed some smoke. the smoke is coming from what seems to be the bottom side of both valve cover gaskets. I've never smelled this type of smoke before, but it doesn't smell like burning oil, burning coolant, or any of the "normal" smells. The car was on for a total of about 5 minutes.
has anyone experienced this when changing a valve cover gasket? Is the gasket just setting itself or what? any help would be greatly appreciated.
