Results 1 to 12 of 12
    Veteran Member Three Rings Jdubya's Avatar
    Apr 05 2006
    05 S4
    Dayton Ohio
    H&R/Koni install
    All this talk of the Koni/H&R got me motivated to do my install.
    I read a couple of the how to's on installing a suspension on the S4's and wanted to make a couple of notes.
    Front suspension. You don't need to loosen the tie rod from the control arms when taking off the struts. When you loosen the upper control arms the hub moves out of the way enough to get the strut out.
    Rear suspension. With the rear subframe supported on the side you're working on, take the subframe bolts completely out and lower it until the spring comes out. Doing this made the rear install very very easy.
    Completed:
    FI DP | FI CB | JHM IM | JHM TUNE | JHM N20 | SB STAGE III/LWFW | PORSCHE BBK | BBS CH | KONI/H&R
    Deactivated Three Rings
    Apr 11 2008
    Re: H&R/Koni install
    Yo J-Dub thanks for the informative thread, tons of people will find this useful.. not only for your install write-up, but for those people (like me) deciding what type of suspension setup they want to go with!
    In, Out and Around...
    is there a link to a diy suspension install?
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    lmao nice license plate
    Sep 19 2007
    seattle
    nice work!
    would you get negative camber for not having the coilover?
    Apr 05 2006
    05 S4
    Dayton Ohio
    Quote Originally Posted by swrt83 View Post
    Glad to help!
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    Awesome. Looks good!
    Veteran Member Three Rings bloodstar57's Avatar
    May 15 2007
    2024 SQ8 E-Tron, 2019 RS5
    LI, NY
    Looks good
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Are you running the H&R Coils with Koni's? That's the setup I have. I'm getting a slight clunk from the left front backing up or first starting out forward. Friggin' dealership that installed them is telling me that it's the coils and that they don't seat the same as the stock springs therefore the clunk. What a bunch of shit.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Apr 05 2006
    05 S4
    Dayton Ohio
    They won't seat the same if they are installed incorrectly. The springs have to sit correctly in the rubber bushings or else it could cause problems. Also if they didn't get the strut bolts tightened all the way down the strut could move up and down causing your noise.
    Veteran Member Four Rings evil_O's Avatar
    May 30 2008
    2017 Infiniti QX30
    Colorado
    Quote Originally Posted by AudiOso View Post
    I am running the H&R coils and have no clunk. I would go back to the stealership and ask them to re-evaluate their install.
    2013 Ibis White S4||P+||DSG||Sport Diff||B&O||Black-Chestnut Interior|| Unitronic Stage II+ & TCU Stage II||Luft-Technik Intake||20% Tint || KW H.A.S. Kit||TSW Bathurst ||Magnaflow res X-pipe||Copious amounts of Xpel| PIAA Plasma Ion Yellow Fogs||ECS 2-Piece Wave Rotors
    May 30 2008
    2017 Infiniti QX30
    Colorado
    Jdubya^^
    Looks great! How do you like the ride? Impressions so far?
    I am thrilled with mine.
