Results 1 to 10 of 10
    Mar 03 2004
    2014 Allroad, 98 A4 2.8, 00 S4, 03 3.0L A4
    Chelsea, MI
    Oil around sparkplugs
    I changed out the sparkplugs this weekend on my 98 A4 2.8. I noticed that at least two sparkplugs seemed to be sitting in a pool of oil. Possilbe cause might be "blow-by" the sparkplug gasket? New plug gaskets can be installed with the smaller diameter ring against the head or against the plug. I went with smaller ring against block.
    Any other thoughts?
    Thanks
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: Oil around sparkplugs
    Had the same issue on my 1.8T. It was the spark plug gasket. I just replaced it and problem solved.
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    Valve cover gasket.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    All 2.8s have leaky valve cover gaskets and cam chain tensioner gaskets.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Its what the other guys mentioned
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    ^^ yes x2
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    It's the middle part that's in this pic. It seals the spark plug tubes to the valve cover
    Mar 03 2004
    Chelsea, MI
    Got the new gaskets and started the job. What a pain. Valve covers do come off, however they seem to get hung up and all sorts of things. Got them off, doing so resulted in breaking of the PCV line. This plastic line was crispy and plugged. Got a new one for about $80. What a pain to replace this line. Had the valve covers hot tanked, also painted them. They look good. Next, I broke a plastic vacuum line. Seems like all of the plastic under the hood is crispy.
    I suspect that having a PCV hose plugged helped to cause oil to leak from the gaskets.
    I haven't really looked yet, so I don't know how the vacuum lines are attached. Also, not sure where to get replacement vacuum line.
    Any advice?
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Quote Originally Posted by Kurt Koseck View Post
    Any advice?
    ECS sells silicone vacuum line by the foot. You can use blue shop towels to soak up the oil in the tubes before you pull the plugs out.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Mar 03 2004
    Chelsea, MI
    Thanks! Went to the parts store, saw many options. Bought 1 ft of small diameter rubber vacuum hose, sprayed it with silicone, slipped it over the ends of the hard plastic OEM vacuum line.
    Pictures coming soon.
