Results 1 to 3 of 3
    Veteran Member Three Rings Rico750's Avatar
    May 19 2007
    B7 S4| 07' R1 | 08' R6 | 09 X6 |
    Tennessee
    replace exhaust gasket? hard to do ? help
    Ok for a few days now i have this anoiing noise coming from under the hood.. it sounds like a hole in my exhaust but it is not. The same noise it made a few months ago when my turbo to cat gasket was blown because my cat bolts came loose.. now i can feel some exhaust gas escaping from the exhaust manifold area especially noticable when i rev the ropm's up.
    So i ordered me a new exhaust gasket to get that replaced. Anyone en idea if that is soemthing i can do myselves or something i need to go see a mechanic for? im comfortable replacing that cat to turbo gasket in the past but for this long 4cyl exchaust manifold gasket it seemd that the turbo needs to be unbolted from that manifold and a bunch of nuts need to come off.. anyone here ever done that? any special tools? and maybe estimate of time?
    Thanks so much!!!
    Rico
    2004 S4 | 18" RS6 rep Rims | Valentine 1 | BOSE + Blaupunkt sound | K&N | H&R sport 1.2" lowering | KONI | 30% tint | FI down-pipes | FI catback 2.5" | JHM tune |
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    Re: replace exhaust gasket? hard to do ? help
    i replaced the exact gasket a few weeks ago because of the same problem, when my nut fell off the opening the leak came from ruined the gasket so when i put a new nut on there was a hole letting exhaust out still.
    take the air box out, remove the 3 cat to turbo nuts. the cat can be pucshed back to get off of the studs and the gasket can be replaced, it can be done in an hour. the turbo doesnt need to be removed.
    May 19 2007
    Tennessee
    Quote Originally Posted by Bic-Ball View Post
    awesome ! you the man ! And do you know if you can reach all those nuts without any probs? thanks!
