Results 1 to 11 of 11
Thread: Crazy Speedo
    Oct 05 2006
    Baltimore, MD
    Crazy Speedo
    Since I went stage 3, my speedometer and gas gauge have been going crazy. They both fluctuate and dont give anywhere near accurate readings. I am also getting throttle cut at about 5,000 rpm intermittently. I replaced the Vehicle Speed Sensor today and that did nothing. The car's original ECU was a T-Box and i'm now using an M-box with stage 3 software. Before I start searching for a pinched VSS wire, has anyone ever experienced this isuue? Thanks in advance.
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Re: Crazy Speedo
    once or twice, my speedo read 10mph when stopped, and kept at 10mph difference throughout that drive. my speedo took a shit on me in my maxima once. because of an electric short.
    This has never happened to me since, so i consider it an anomaly. knock on wood. hope you figure out what's happening. The speedo is pretty important!
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Oct 05 2006
    Baltimore, MD
    Re: Crazy Speedo
    any advice anyone?
    Oct 31 2005
    Ashburn
    Re: Crazy Speedo
    did you recode the cluster after the swap of the ECU's. As for the gas reading i would say it's the fuel pressure sender that went bad.
    - Instagram: @Sinister_rs5-
    Established Member Two Rings jwk2w's Avatar
    Jul 02 2008
    '00 Nogoro S4, '82 280zx
    Hot Springs,Ar
    Re: Crazy Speedo
    I just bought a 2000 s4 and I had to drive 1100 mile home from getting it. On my way home in Nashville, TN I hit a back rain strom and my speedometer did the same thing but is a couple hours is went back to normal.
    Oct 05 2006
    Baltimore, MD
    Re: Crazy Speedo
    No, I wasn't aware that I needed to recode the ecu, is that done thru Vag software?
    Jul 31 2007
    Boston
    Re: Crazy Speedo
    Quote Originally Posted by jwk2w View Post
    Haha that happens to me too, after i wash it or while it rains my speedo doesn't work, my odo doesn't go up and my gas gauge bounces around.
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Oct 05 2006
    Baltimore, MD
    Re: Crazy Speedo
    Thanks, gonna try this once I can get my laptop to connect.
    Veteran Member Three Rings audi_s5's Avatar
    Jan 04 2009
    AUDI RS3
    WI, USA
    Re: Crazy Speedo
    My allroad speedometer does same thing after car wash/heavy rain.
    Anyone know what the cause is? Is it VSS? or something else??
    AUDI S5 - Ice Silver/Black Napa Leather, Side Assist, NAV, TECH, B&O, Carbon Inlay, APR ECU Tune, Exhaust, Ohlins Susp Pkg/Swaybar, MTM Brembo 8 piston brakes, Dimpled Rear Rotors, RS5 20" Wheels, LED Taillights,Auto Fold Mirrors, EUR FB Steering Wheel
    2011 AUDI S4 - Ice Silver, Prestige, ADS w/ sport diff, B&O, EUR FB Steering Wheel, APR stage II+, APR CPS, Armytrix Valved Exhaust
    A3 S-lineBril.Black,2.0t,DSG,NAV,APR Stage II+, S3 Euro Conv, Recaros, Forge Twintake
    May 26 2009
    '03 Passat 4motion
    Bell Canyon, CA
    Re: Crazy Speedo
    I have run into this multiple times working at the dealership. The only fix I know is run new wires from the speed sensor to the cluster. Its no small job, but I can almost guarantee that's the issue.
